My printer loses wifi connection every few days. I get the error message when I go to print that I must first install a printer. I look and sure enough the printer is not installed. Sometimes when I shut off the whole computer and power it back up,, the printer re-connects. Why is this happening and what can I do to fix this ?
Follow The Steps To Fix Canon Printer Not Connecting To Wifi Error:
Solution 1 - Check Internet
Check your network connectivity first, sometimes the internet connectivity is low which cause network issue.
Solution 2 - Remove Barriers
If there is any barriers between your device and router then remove them right now!
Solution 3 - Disconnect Other Devices
Don't put the printer with the Wifi router to make a suited distance. It's not only the barriers but also if the network you are using is connected with other appliances too then it may also create network problem to you.
Solution 4 - Reboot Your Device
Now, you do not have to do anything, just restart your device and check whether the error is solved or not.
I hope these steps help you a lot in fixing the canon printer won't connect to wifi.
It could be that your printer or your router is losing the ip address. You can set a permanent IP address in the machine on the same range as your router. eg 192.168.x.50.
This means the router will always find it and you can also set the address in printer port settings on your computer in the control panel.
SOURCE: canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
I have canon PIXMA ip3000. After power cut at night printer doen not
print. I re installed the drivers but no result. When try to print
message appears printer is offline. POwer button is flashing shorthly
green after orange lights. Error code 5100.
Please advice what can I do urgently.
SOURCE: Canon Pixma MX310 won't scan or print
try unplugging it for a little bit then plug it back in and try again if this doesn't work then do a fresh install
SOURCE: error 306 is happening each time i try to print document.
I reloaded the printer driver and it worked again.
