I have a phillips 42'' plasma model number 42PF732OA/37 the tv run's for about 5 minutes then there is a LOUD static noise screen goes blank and shuts itself off. the light on the front stays green the whole time, then if i leave it on it will just sit there and make a clicking sound. wondering if anyone has similar problem?
SOURCE: Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer
Antenna is not hooked up to television.
Problem is caused by television broadcast
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
SOURCE: Philips 42 in. Plasma shut down
Thank god we purchases the ADVANCED extended warrenty. This tv has been nothing but problems.
Fuzzy picture, picture shutting off after 20 sec coming back on and now blog of colors shut off never to come on again. 7 blinking red lights on the front. Waiting for the repair man again.......
SOURCE: Black Screen after 5 mins. of use
It sounds like the entire screen goes blank with your problem. My problem is the lower half of the screen goes blank. Do you think the SSB is also the problem? What are your thoughts about the "Video Board" or the X Board?
Do you know where to purchase parts?
SOURCE: Philips 42PF7220A/37 42" Plasma TV
After you remove the back cover inspect the power supply board for swollen or bulging capacitors. Pull and check any capacitors that you suspect to be swollen. Next, look for a sticker in the upper right hand side of the TV set. Use the values you find on the sticker to calibrate the voltages on the power supply board.
SOURCE: Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
