tried to magic focus it- but the magic focus gets stuck on the red color and won't go any further. Red blurry color is now showing on tv-
don't know how to fix?tried to magic focus it- but the magic focus gets stuck on the red color and won't go any further. Red blurry color is now showing on tv-
You can't post conmments that contain an email address.
The tv have a problems known as a convergence picture problems it is dead.The tv have any colors lines like R,G,B mis alignments,tv have any colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead and the causes of these problems.The tv convergence board must have to repair like replacing like 2 STk covergence ICS and some or all of it resistors too.To fixed the tv convegence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?This tv have a dead convergence board.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.Fixing the tv convergence board,will solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Flash Focus magic button no longer work.The tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures problems.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost $300-350 for parts and labors.
Replacing them requires a lot of soldering and a knowledge of circuit boards.
Is the TV worth saving? is it bright and clear? was it good (when it worked?) ifthe answer to all of these is yes, then you have a few choices. If anyof these are not true, then you should just get a new tv.
Your choices are: Ifyou are good at soldering, then you can attempt to replace the IC'syourself. (with all of the parts handy, it should take 1 hour)
Ifyou aren't good at soldering, then you can have a friend do it for you,or you can have a mechanic fix it. (tell them that its the convergenceIC's that went bad. (pay no more than $200 for the job).
Thesego bad on almost all projection tvs eventually. They overheat and burnout, causing the screen to go in/out of alignment and make wavy lines.
I have a Samsung Tantus HDTV 55in. I am not getting a full screen. The screen alignment is shifted to the right. I am not getting the full picture quality, just partial. Can you help me?
I have the same problem
I HAVE THE SAME PROBLEM.
I CANNOT FOCUS. THE MODEL NUMBER IS:
61SBX59B VOAO19032
MANUFACTORED IN JAN 2000
