Question about JAKKS Pacific Eyeclops Bionic Eye Tv Plug-in Microscope
Vox mini led projector light blinking problem
I have purchase an vox led projector .it worke nicely for 2 hrs but afterwards the projector does not starts .the light continuously blinks but there is no display.please give me a sollution for this problem
    New Friend:
I dont think it as solution. when power on, it has to show the VOX logo initially. Later we can set the i/p mode...
I had the problem with my new led vox projector. Larer I replaced it. now I got the same issue with the replaced product. Each time I used only 2 to 3 hrs the device. Waste of buying such brands.
Posted on Oct 13, 2013
  • MAXkhan
    MAXkhan Oct 21, 2013
    I had the problem with my new led vox projector. WHERE i replace it ,i bought mader chood NAAP TOL.COM .IHAVE SAME PROBLEM.
2 Suggested Answers
SOURCE:
micromatikal
  • 2777 Answers
SOURCE: our mini eye clops projector
It sounds like this may be a problem with the source of video, not the projector itself. Have you tried multiple things attached to the device? Video game system, dvd player, more than one thing for example? Also try a different set of video cables to connect to the device to see if it is the cables.
Let me know what you find, just reply to my answer here and I can help!
Thanks
Tim
Posted on Nov 01, 2010
Vox vt40 factory reset
Consider reading the Manual for this amp, it explains how to reset to factory with the VFS5 footpedal. Or with the power off ..hold down CH1 & CH4 then turn power on.. when the Bank & Channel leds start blinking.. then release the Channel buttons. Next press the Tap switch ... the bank & channel leds will change from blinking to lit. with in a few seconds it will enter preset mode.
Apr 12, 2014 | VOX Amplification Vox VT40+ Valvetronix...
Infocus 4805, wont power up remotely
the lamp has burned ot and needs replaced,
Nov 25, 2007 | InFocus ScreenPlay 4805 Multimedia...
Power light of projector is blinking
my red light blinks to.. did u ever solve it?
Apr 04, 2014 | FAVI RioHD-LED-2 Mini Projector
I my projector is new one used for 4 hrs, when i try to turn it on it just has a blinking green light. Please help Solve It! .
The blinking green light means the unit is either Powering On (Warming Up) or Powering Off (Cooling Down).
Powering On the Projector
1. Remove the lens cap.
2. Securely connect the power cord and signal cable. When connected, the ON/STANDBY LED will turn Amber.
3. Turn on the lamp by pressing " " button either on the top of the projector or on the remote. The ON/STANDBY LED will now turn Green. The startup screen will display in approximately 10 seconds. The first time you use the projector, you can select your preferred language from quick menu after the startup screen displays.
4. Turn on and connect the source that you want to display on the screen (computer, notebook, video player, etc). The projector will detect the source automatically. If not, push menu button and go to "SETUP". Make sure that the "Source Lock" has been set to "Off". If you connect multiple sources at the same time, press the "SOURCE" button on the control panel or direct source keys on the remote control to switch between inputs.
If you are still unable to get the unit to turn on, try unplugging it for 10 minutes and plugging it back in. If it still ceases to work, contact Optoma here: http://www.optomausa.com/rma_policy.asp
Their Technical Support line is 1-888-887-5001
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 25, 2011 | Optoma HD20 DLP Projector
I had a bulb burn replaced both bulbs worked for a couple of days but now it wont power up only lamp1 light blinking. I have tried taking bulbs out and putting them back in still nothing, also the lamp...
the lamp units should be properly aligned with the 2 very tiny switches
between them. If not lamp led will blink.
If lamp led is continuously on, lamp timer has to be reset, according instructions that come with new units.
Original lamp modules are AH-45001 and AH-45002, two different
units needen for 1 projector, reset procedure is different for each lamp !!
Dec 21, 2010 | Eiki EIP-4500 DLP Projector Multimedia...
I have purchased 3 new lamps. one lasted 900 hrs.
Your lamp is rated for 3000 hours. Is the fan working to cool the lamp? When you turn off the projector do you allow the fan to continue to run? If not the lamp is not cooling evenly and the lamp will fail. Th filters should be cleaned regularly and the vents be unobstructed.
May 14, 2010 | Toshiba TLPLMT70 Projector Lamp
No picture and a red blinking light. no output from projector
reset the lamp hrs. do this by holding in the 2 keystone buttons then switching the unit on. keep the buttons pushed in for 30 seconds. if this doesn't work, replace the lamp.
Apr 18, 2010 | InFocus ScreenPlay 4805 Multimedia...
Shutdown & error led blinking 2 times
Shut off your projector by swith on the back near the AV inputs, leave it off for about five minutes. Then switch it back on, manually press the power button, let it start for about 5-10 seconds then continue to hold power button until picture appears. It worked for me, good luck to all.
Mar 24, 2009 | NEC HT1100 Multimedia Projector
JAKKS Pacific Eyeclops Bionic Eye Tv Plug-in Microscope Logo
514 people viewed this question
Top JAKKS Pacific Toys Experts
ray gallant
ray gallant
Tom Chichester
Jean DeLauche
Jean DeLauche
Are you a JAKKS Pacific Toy Expert? Answer questions, earn points and help others
