The Nokia C7 have several issues with the factory installed SIM card reader. Problem can be solved by replacing SIM card reader. Either find your nearest cell phone repair store or buy your own online and replace it yourself.
First All Check: 1.Confirm whether same sim card is working in other h.s or not. 2.Make sure the sim slot is o.k. only try these two. 3.If all the above steps fails, check the SIM card connector pins for damage. if so try to get serviced. 4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD. u can make it jumper mean u can fix this prob with out sim card is for this contact. 5.take sim connector slight up by pin then cheak by inserting sim. 6.hot air gun on sim i.c. then cheak it. Last Option: IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service & Sim Office and Get the Duplicate Sim Same Your No From Office Oprator Problem will Solved Quickly
<span><span>Always the Best way to Unlock Your Phone is by using the MEP2 code or Unlock code. First you should<a href="http://unlockgenie.com/"> Purchase the Unlock code from a Trusted Vendor.</a><br /><br />After u got the code follow the instructions below......<br /><br />BlackBerry Unlock Instructions (9800)<br /></b><br />* Insert a foreign SIM Card<br />* Power on the phone<br />* When prompted, enter your unlock code<br /><br />BlackBerry Unlock Instructions (83xx/85xx/88xx/8900/9000/9300/96xx/97xx)<br /></b><br />* Ensure a SIM Card is inserted<br />* Go to 'Manage Connections'<br />* Click on 'Turn All Connections Off'<br />* Go to 'Options'<br />* Click on 'Advanced Options'<br />* Click on 'SIM Card'<br />* Type 'MEPD' (letters will not appear on-screen but a menu will pop up.)<br />* Type 'MEP2' (user will be prompted to enter MEP code)<br />* Enter the MEP2 code (CONFIRM you get "Code Accepted" message)<br />o *If you also have a MEP4 code, type 'MEP4' (you will be prompted to enter MEP code)<br />o Enter the MEP4 code (CONFIRM you get "Code Accepted" message)<br />* Reboot device<br />* Go to 'Manage Connections'<br />* Click on 'Restore Connections'<br />* Device is now unlocked<br /><br />BlackBerry Unlock Instructions (95xx)<br /></b><br />* Ensure a SIM Card is inserted<br />* Go to 'Manage Connections'<br />* Click on 'Turn All Connections Off'<br />* Go to 'Options'<br />* Click on 'Advanced Options'<br />* Click on 'SIM Card'<br />* Tilt the phone horizontally, click the BlackBerry button and Show keyboard<br />* Type 'MEPD' (letters will not appear on-screen but a menu will pop up.)<br />o *If MEPD doesn't work, try MEPPD<br />* Type 'MEP2' (user will be prompted to enter MEP code)<br />o *If MEP2 doesn't work, try MEPP2<br />* Enter the MEP2 code (CONFIRM you get "Code Accepted" message)<br />o *If you also have a MEP4 code, type 'MEP4' (you will be prompted to enter MEP code)<br />o Enter the MEP4 code (CONFIRM you get "Code Accepted" message)<br />* Reboot device<br />* Go to 'Manage Connections'<br />* Click on 'Restore Connections'<br />* Device is now unlocked<br /><br />Blackberry Instructions (81xx/82xx/9100)<br /></b><br />* Ensure a SIM Card is inserted<br />* Go to 'Manage Connections'<br />* Click on 'Turn All Connections Off'<br />* Go to 'Options'<br />* Click on 'Advanced Options'<br />* Click on 'SIM Card'<br />* Type 'MEPPD' (letters will not appear on-screen but a menu will pop up.)<br />* Type 'MEPP2' (*Note- for Telus, use MEPP4. You will be prompted to enter MEP code)<br />* Enter the unlock code (CONFIRM you get "Code Accepted" message)<br />* Reboot device<br />* Go to 'Manage Connections'<br />* Click on 'Restore Connections'<br />* Device is now unlocked<br /><br />Old School BlackBerry Instructions (87xx & Older)<br /></b><br />* Ensure a SIM Card is inserted<br />* Go to 'Manage Connections'<br />* Click on 'Turn All Connections Off'<br />* Go to 'Options'<br />* Click on 'Advanced Options'<br />* Click on 'SIM Card'<br />* Type 'MEPD' (letters will not appear on-screen but a menu will pop up.)<br />* Hold ALT key and type 'MEPE' (user will be prompted to enter MEP code)<br />* Enter the unlock code (CONFIRM you get "Code Accepted" message)<br />* Reboot device<br />* Go to 'Manage Connections'<br />* Click on 'Restore Connections'<br />* Device is now unlocked</span></span>
Looks like your card is damaged - or connector is malfunctioning. Try to clean your SIM's contacts with a gentle pencil eraser first. If it doesn't help try device with the other SIM card. If it able to read another card, just replace yours in yours carrier's store.
Hi.Insert another sim card to your phone and try.if this doesn't solve , clean the sim card slot connector.Otherwise you need to contact a mobile technician.And if another sim card is working in your phone and your sim card shows Rejected to every phone,then the last solution is to change another sim card from the particular sim card provider.Good luck
Take our the sim card and wipe the copper area with a soft cloth. Re-insert and then check. If it still doesn't recognize, try inserting the sim in some other phone. Also try some other sim in the galaxy s2. This would ensure whether its the sim or device thats faulty.
one reason might be is that , your phone might be network locked and hence it is rejecting other SIM, If that is the case try unlocking your phone to use other networks, http://www.theunlockarena.com/ will help you with the process
i have a friend almost has the same problem as yours with N73,
and when it turns on it wont even send a single message.
try cleaning up the sim slot and the sim card itself, and if this doesn't work you'll need to take your phone to the nearest nokia service center.
(please vote for me)
Using the sim card from your tracfone in another phone is possible if both of the phones are unlocked. This means that the sim card if inserted into any phone, that phone will recognize the sim card. If you place your Tracfone sim card in any other carrier's phone and it doesn't work you can call trachoma and they can unlock the sim card.
try to reinsert the SIM and check if it works, You may press and hold the power button while the battery is removed. If it doesn't work, kindly contact nokia bout this issue
