Timex Expedition 40141 Wristwatch Logo
Posted on Aug 30, 2007
Watch battery replacement
Replaced battery in Timex Expedition watch; now I can't get the back cover on again! Won't snap back into place.
  • 4 more comments
  • al-pat Sep 01, 2008
    I have replaced the battery once before with no problem. This time it was really hard to get the cover off to replace the battery. I purchased exactly the same type of battery (Energizer CR2016) but I cannot get the new battery to snap in so the watch is running, and I have trouble getting the back cover to snap in. If I press down on the battery a certain way it will run but when I let go the battery falls out. When I press down on the cover, the watch doesn't run. Is there something I'm doing wrong?
    Albert Yaremchuk
    emial [email protected]
    Phone 250-545-8509
  • suwie Apr 06, 2009
    Same problem with my indigo watch.
    I used a wooden chopping board on a table and slid a wooden rolling pin in the strap, pushed down hard in case with all my weight and it popped in. (place some protection under the watch face on top of board).
  • Anonymous Mar 04, 2013
    First, I took out the pin holding the clasp, so I could completely open the band/clasp, so it was easy to work on the watch. Yes, it's hard to get the battery to stay in place, but it isn't necessary. Just holding the battery in place, I could verify that the watch would work. Holding the battery in place, I carefully slid the back of the watch in place. Then I used the rolling pin trick; I placed the watch on a towel on the kitchen counter, and used a rolling pin to push down hard, trying to apply even pressure. I rocked side to side, and at one point, it slid into place with a loud snap. That's it!
  • Anonymous Mar 12, 2014
    It's suppose to snap into place but after many hours of lining the back up correctly I simply cannot seem to snap the back on. I've push as hard as I can and it just won't budge.
  • Anonymous Mar 20, 2014
    I have an older model Timex Expedition watch. I just changed the battery and the beepers stopped working. It has been a great watch. can anyone tell me how to fix this.
    I have a timex expedition watch. It is an older model. I just changed the battery and now all the beepers have stopped. How can I fix this?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Sep 28, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5258
Points
10
I have a Timex Expedition Indigo with a metal case. Not sure of the exact model number but on the back there an M6 below Expedition. Anyway, I had the same problem of snapping the back back on. I found a "battery" website that had some suggestions that should be typical of any snap back case watch. http://www.online-batteries.co.uk/whichbattery.shtml specifically they said that when you try to press the back on it must be flat (not one edge down as I had been trying) Put the watch face down on a non scratch surface and press with both thumbs evenly. If that doesn't work a press will be needed. If you have a vice a couple of blocks of wood to distribute the load on the front and back may work, otherwise take it to a jeweler with the proper equipment. The thumb routine didn't work for me. I have a vice but figured many wouldn't so I tried something else first. I put the watch face down on a piece of wood. I found a small 2" long scrap of wood (3/4" x 1.5" approx) that spanned the back. I centered the back (aligned properly) placed the block of wood squarely and centered across the back and tapped the end of the block with a hammer. First try didn't work, second one did. I used a rubber mallet as the hammer but a regular hammer or other heavy object would work. The trick, I think, is to get everything lined up and square so the blow is centered and even. Also, I'd suggest cleaning the back and the groove in the case and be sure the rubber gasket is properly positioned. This will give you the best chance of retaining the waterproofing. And remember to check that the watch is running before you do this. Some need to be reset (usually with a very small screwdriver or pin) after replacing the battery. There should be a small hole with some printing next to it. You may need a magnifying glass to see/read it. Good Luck, Richard
  • Curt Fox
    Curt Fox Oct 29, 2013
    After reading many suggested methods, and failing repeatedly, I finally chanced upon an absolutely fool-proof way to do this. I palced the watch on a hard surface (my workbench), took a very large brass mallet and smashed the watch to smithereens. I then went down to my local Walmart and purchased a replacement for not a very reasonable price. Practicality? Quite low, I suppose. Frustration relief-priceless!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 11, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4731
Points
I'm female and my solution reflects it. Couldn't get my husband's Timex back together after chaning the battery. I put the face down on some folded paper towel and put my rolling pin through the watch band where the wrist would go.. Making sure the back was centered, I pressed down hard on the rolling pin, then rolled it downward. It popped into place and my husband thought I was a genius.
  • Carol Apr 17, 2013
    The rolling pin trick worked like a charm for mine! Thanks.
Anonymous
Level 1:
  • Posted on Jun 24, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4731
Points
I had the same problem, it was solved by using a "G" clamp. Wrap the watch in a few layers of kitchen towel and put it in the jaws of the clamp, aligning the center of the clamp with the center of the watch. Screw the jaws together and listen for a dull "snap" - job done!
  • tonyg1956 Sep 21, 2010
    This clamp approach worked very well for me. I used a "C" clamp (Is that the same as a "G" clamp?). I just put about 4-5 layers of paper towel on the crystal surface and put the movable part of the clamp directly on the back of the watch. This way I could make sure that the back started out even all around. I slowly tightened the clamp and heard a little pop as it tightened just a little. It worked great. Remember to insure that the battery is properly seated before you do this. I tried the hammer approach above but it did not work but the battery came unseated while trying some of the other techniques.
Anonymous
Level 1:
  • Posted on May 29, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4731
Points
Just wanted to warn people if you have a indiglo model in my opinion don't try the piece of wood and tapping with a hammer as it has broken the indigo back light and i was only tapping very very lightly as it is not one of the cheaper models, so i aint to happy at the moment, but at the end of the day it's my own fault as i should have taken it to the jewellers in the first place and would also be the best option for anyone with this problem.
Anonymous
Level 1:
  • Posted on Mar 05, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4731
Points
My solution for my wife's Timex was to lay the watch face down on a flat piece of wood placed on a flat immovable surface like a a work bench or even the floor. Next, I took another piece of flat wood slightly wider than the watch case and about four inches long. I carefully placed it down upon the case cover after centering and leveling it over the groove. Then I pressed down evenly with increasing force (gentle but firm) until I heard the back of the case snap into position. Prior to this I cleaned the groove with a brush dipped in alcohol. I also lubricated the seal with some Harvey's silicone plumber's grease. The silicone grease will help the seal maintain a waterproof junction . Wipe off any excess before reassembly. They sell it at most hardware or warehouse stores that sell plumbing products--though most clerks will not know they carry it. It is a must for "O" ring style plumbing facet washers or seals. They cannot be lubed with any petroleum grease product as they will start to dissolve. It can be used on other rubber-like seals as well. Jim.
Anonymous
Level 1:
  • Posted on Oct 07, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4731
Points
6
I used a modification of the vise solution. I put a plastic bottle screw cap on either side of the watch (bottle side in) and tightened the vise. I heard a satisfying "pop" and I am on my way. Fred
Anonymous
Level 1:
New Friend:
  • Posted on Aug 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4731
Points
I put the watch on a cutting board with a paper towel on the face. I slipped a furring strip about 3 feet long thru the band and pushed down evenly on both sides and the back snapped in. Thanks for the above ideas.
Anonymous
Level 1:
  • Posted on Sep 27, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4731
Points
I struggled with my Timex (a yard sale buy) after putting in a new battery. After reading here how to place it face down on a block of wood (my cutting board) and placing the back level (not with one side already set in), I placed another block of wood on top and tapped it a light hammer tap. It popped into place first try. Thanks.
dkentstewart
Level 1:
  • Posted on Sep 14, 2009
dkentstewart
Contributor
Level 1:
Answers
Questions
Helped
4731
Points
Thanks to everyone for the good advice. I have a Timex Indiglo (large face) watch, replaced the 2016 battery, and couldn't get the back cover back on. After trying all the ideas with no real success (and fear of trashing the "indiglo" feature, I settled on using a 3/4" PVC coupling, which fit the back just right to distribute the force fully and avoid putting too much pressure on the center. I used tape to align the back just right, placed the front onto a cork coaster, set the PVC coupling on the back, and used a flat wooden kitchen spatula to press evenly on the PVC/back. Didn't get the satisfying "pop", but did feel the back go in.
Anonymous
Level 1:
  • Posted on Jul 06, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4731
Points
My girlfriend held one set of pliers and I held another on opposite sides of the watch, with a washcloth to buffer the watch, we counted :"one, two, three" and on three we both pressed at the same time and it worked.
Anthony Stratton
Level 1:
  • Posted on May 06, 2008
Anthony Stratton
Contributor
Level 1:
Answers
Questions
0
Helped
4731
Points
Whew, thank you for the help R Barkley. It was surprising how difficult it was to get the back of the watch in place. I think a back that screwed on with a slot for a flat edge screwdriver would be much easier to deal with. I have a Timex generic model. It says indiglo on the face.
I tried pushing evenly on the back of the watch with my thumbs and that worked! I'm 6 feet and 3 inches tall and I have large hands, so I think that's why the thumbs method worked for me.
Happy spring, have an effervescent day!
P.S. Here's a splash of humor for you.
The Germans are exceedingly fond of Rhine wines; they are put up in tall, slender bottles, and are considered a pleasant beverage. One tells them from vinegar by the label.
-- Mark Twain, A ***** Abroad
A
Anonymous
Awesome you guys! Thanks for posting. I was having a terrible time with my wife's Timex Expedition. Then I tried my own modified vise treatment after reading your posts -- I used small pieces of wood and squeezed it with a large vice-grip pair of pliers. It didn't work when I first tried it, until I read above that you needed to be sure the watch back was level -- not half popped in on one side. Worked very well -- she'll be happy to not take it to a jeweler. Thanks.
3 Related Answers
Anonymous
  • Posted on Jun 17, 2009
SOURCE: How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
Anonymous
  • Posted on Feb 25, 2010
SOURCE: Expedition Indiglo Waterproof 50m
how do you change the battery on this
Anonymous
  • Posted on Sep 03, 2010
SOURCE: Replaced battery in my Burberry watch, back cover won't snap on
I have the same problem. Did you guys find how to do it? Please let me know. M
3helpful
I cannot replace the back of a timex 1854 watch. I replaced the battery but the back won't click on
I used a four inch "C" clamp and a large washer about diameter of back, to get my Timex back snapped back on. Place the watch face side down on a flat surface cushioning the crystal with soft rubbery material like shelf liner or anti skid material used under rugs (the kind used to also line tool chest drawers - black). Place the washer between the watch back plate and the "C" clamp screw plate. Align the back plate of the Timex as evenly on watch as possible while gradually tightening the "C" clamp. Keep turning down the "C" clamp ever so slowly until you hear the plate snap back on.
Jun 28, 2011 • Watches
1helpful
My battery is running dead . Can I have it replaced ?
Yes, the battery for this watch can be replaced. Timex estimates that the battery should last 2-3 years, but that assumes an "average" use of the Indiglo backlight. If you never use the backlight or audible alarms, your batteries would have lasted longer; heavy use of both would have run the battery down more quickly.
If you want to replace the watch battery yourself, you'll need a very fine philips or flathead screwdriver, the new battery, and a bit of patience. It would also be helpful to have a pair of tweezers, but that's not absolutely necessary. If you carefully look on the back of your watch, Timex usually lists the battery type so that you can buy a replacement battery without first opening the watch. If you can't figure out what the numbers mean, take it to a jewelry counter at Target or Walmart, and they should be able to help you decipher it. I don't know which battery this specific watch takes, but many Timex watches use a #1620 or #2016 3v battery. Look for a number like that on your watch back.
To open up the back of the watch, open the strap so that you have good access to the back. If you have a steel band, you might need to slip out one of the adjustment pins to separate the band into halves. Yes, you might be able to take the back off without this step, but it makes it a lot easier.
Place the watch face down onto a soft surface. I like to use a dark towel, so that if I drop one one of the tiny screws you'll be dealing with in a minute, they won't bounce and you can easily find them again.
Use your screwdriver to loose the back of the watch, one screw at a time. I find it very helpful to loosen a screw, then use the tweezers to pick it up out of the hole. These guys are tough to grab with your fingers! Put the screw in a safe place, then carefully remove the back of the watch. A little black neoprene gasket may be stuck to the back or be floating around--don't lose that!
You should be able to see where the battery is kept. On most Timex watches, there's a metal shield covering the watch and completing the power circuit. Using your screwdriver, gently pry the tabs of this shield away from the watch movement, one tab at a time. Try very hard not to snap off any of the little plastic anchors. On a Casio watch I recently serviced, I had to remove the movement from the watch to get at these little tabs; I don't remember ever having to do that with a Timex.
Once the shield is loose or removed, the battery should slide right out. Replace the battery, and gently snap down the metal shield. Turn the watch over to check whether it's working again. If it's not, you may have to push a little "reset" pin on the watch movement to clear the registries. The back of the metal shield usually has instructions on where that little pin is located. If the watch is already working, you won't need to do this.
Closing up the watch is the reverse of what you did to get it open. Make sure the neoprene gasket is back in place--that's what's keeping sweat and water out of the watch--and carefully set the cover back in place. Tighten the screws in an "X" pattern--i.e., top left, then bottom right, then bottom left, then top right. I get all the screws loosely screwed in before tightening them down in earnest. This watch has a plastic case, so you want to tighten the screws snugly, but not over-tighten them so that they strip out the screw hole.
The back doesn't seem to want to snap back in
Try a very small dab of a very light lubrican on the sealing edges.
If you haven't already tried it, press the edge of the watch back using two fingers and move them appart until they meet again.
Season with a lot of parience... good luck!
CHanging battery on timex expedition, cover says
If you don't have the proper tools I recommend that you not do this yourself. You could scratch the case or damage the movement if you don't know what you're doing. If it's a water resistant watch the gasket also needs to be replaced once it is opened. DO NOT reuse a gasket! For about $8 any watch or jewelry2_bing.gif store can change the battery and renew the gasket for you.
9helpful
2helpful
My watch needs battery evry 15days
Your problem may be that the back MUST be replaced in exactly the same orientation as it was removed. On mine the lettering on the back must oriented so as to read with the top at 12 O'clock. In other words, if you look at the watch face with 12 at the top (normal) then rotate to the back and place the back on so the words can be read. I hope this makes sense. Top of the words on the back must be exactly at 12 O'clock
Timex Men's Digital Expedition Chrono Alarm Timer Watch battery
hi
please follow the steps to change the battery
  1. Step 1 Make sure the little arrow on the back is aimed to the right. Then, insert a small flat head screwdriver into the notch on the edge, and lever the back open. Place the back to one side.
  2. Step 2 Unscrew the clip holding the battery (if your model has a clip), and remove the battery.
  3. Step 3 Use plastic tweezers to put in a new battery. Do not directly touch the new battery. Screw the clip (if it has one) back on.
  4. Step 4 Replace the gasket that seals the watch. Then lightly coat the gasket with a silicone-based grease.
  5. Step 5 Align the back with the little arrow aimed to the right again, then carefully press the watch between two pieces of wood that are being held by a small vise, until the back seats itself.
thank you....
2helpful
3answers
Expedition WR50M
I had the same problem. The thing that was most frustrating is that I have a standard tool to remove and install screw in watch backs, but Timex in its infintie wisdom, decided to make this model withta snap-in back.
I tired usinga a set of adjustable locking pliers with rubber claw covers. I tried holding one side with finger and thumb while using the pliers on the other to no avail.
robatbath's answer about jewelers having a special press led me to a solution. I just happened to have (2) 1.25" steel washers with 1/4 inch holes. I placed one on the face and one on the back. This way I could use the locking pliers (with rubber covers on) to press in the center of each side. The back snapped in fine. You can get washers and pliers at any hardware store.
1helpful
Skagen ladies watch
izzi, I assume you have a snap back back that won't snap back in place. I had the same problem with a Timex EXpedition. The solution should be similar. See my post" http://www.fixya.com/support/t190459-watch_battery_replacement and also the site I reference there. http://www.online-batteries.co.uk/whichbattery.shtml Good luck, Richard
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
