Casio Parts Cash Register PC Desktop Logo
Posted on Mar 31, 2009
I need to know how to program a new tax rate
I can not figure out how to program a new tax rate
  • 1 more comment
  • Anonymous Mar 31, 2009
    casio ce 6000
  • Anonymous Apr 01, 2009
    how do i change Tax rate?
  • Anonymous May 11, 2010
    what is the make and model of your cash register?
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Apr 14, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
1911
Points
7
Move the pgm key to pgm mode 3 subtotal 125 subtotal ( tax table) rate tax and subtotal beginning  level tax ejemplo : for ten cent = 10  and subtotal 5002 subtotal subtotal.
to applay the tax to dept or plu
move the pgm key to pgm mode 3 subtotal 366 subtotal 1 and all dept o plu  subtotal
I have a sharp xea40s cash and i cant get 11 thru 20 to be taxable i can program them and all that but will not add tax
In department programming, there will be an option to add each tax (tax 1, 2 , 3 etc.) turn on the tax that you set the rate for - usually tax 1 - for each of the departments that need it.
I have a TE-2200 Casio cash register. I try to program in tax rate and nothing happens. Can someone help
If you have changed the tax rate, it should print out the change you made to confirm the change as soon as you finish programming. After that, it should use the new rate. If it is not adding tax to items, make sure you have linked the tax rate to the items in PLU or dept programming (whichever you are using)
3helpful
3answers
Manual for Casio MS-120TE Calculator or how to program exchange rates
press AC
press RATE SET, hold for approx5 secs till you see "tax" "%" displayed
type in new rate (say 20)
press RATE SET (to confirm 20% as new tax rate)
Done
7helpful
2answers
Programming of the casio pcr-t275
Hi program the taxes like the book says but fix the gst rate, then go to program mode and push 1 subtotal, then push t/s1(taxtable 1 which is gst) and the dept number you want to use, then subtotal and cash and that will be the dept you will use for just gst. Hope I'm making sense. Took me forever to figure this out.
Changing tax rate on the casio te-2000?
Hi.
I don't have the USA version, but most states just use fixed rate tax, so I can probably help you.
I need you to print the current tax so I can see how it has been setup.
Turn the key to Program mode.
3 SUBTOTAL SUBTOTAL (must press subtotal twice)
Make sure you turn back to REG mode.
This will print a list. Look down until you see 0125 through 0325 on the left.
Tell me what the figures are on the right of those three. There is usually three sets of figures for each. don't worry about anything else on the print out, just the info next to 0125, 0225, 0325.
Mark
2answers
How to program tax rate for te-2200
Hi. If you bought it new then your dealer should have set all of the system options for you so it is strange that the tax is not programmed. Normally you would only need to set the rate when your tax rate changes. Has it been calculating tax at all? Did it come from your dealer with a standard program in it?
2helpful
Tax button
under the GT button at the top, switch that button to the "Rate"..enter whatever % tax rate you want. Then move button back to off setting.
enter your number and hit the plus sign, then the tax+ button or the tax- button. it will automatically figure the tax for you. You may have to play with it a bit..I got the pdf version from the canon tech geeks, and the directions leave lots to be desired. Good Luck!
CASIO TE-3000s , i would like to change the tax rate on my "grocery tax" button.
Hi.
Try turning the key to program mode then,
type new rate (you may have to add decimal places such as 8.00 or 8.000)
Then press your grocery tax button
Then press SUBTOTAL
Turn back to REG mode, and try it.
Let me know if it doesn't work.
Mark
3helpful
Need to change tax function on Sharp EL-334A
I had the same problem and finally figured it out. Here's what you do:
Press C-CE twice
Press +TAX (Rate set)
Key in your new tax rate as an integer (e.g. 5)
Press +Tax (Rate set) again
Press C-CE
Then you're ready to calculate with the new rate!
Now what's the GT button for?
2helpful
3answers
Tax rate, user guide
hi Jocelynn As far as I can figure out, to reset ur tax rate, all u need to do is put the gt button to tax rate-- then type in the new rate -- set the gt button to off. eg:- gt button to tax rate- type in 5(5% tax rate)-- gt button off Hope this solves ur problem. For further contact [email protected]
Top Casio Retail Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
