Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
Posted on Mar 31, 2009
Do not know how to add dishwashing liquid to machine
I moved into a house with this type of dishwasher. I put the soap in the two pull out containers but they do not open, nor if I leave them open does the detergent drain out. I am sure the solution is simple but I cannot figure it out
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Mar 31, 2009
Anonymous
Contributor
Level 1:
Answers
22
Questions
0
Helped
35359
Points
83
Fill your clean, dry dispenser cup with detergent and close it.The water streams through the closed dispenser and comes out at the bottom of the dispenser. Make sure you have 120 deg f water coming to the dishdrawer and never put anything in that dishwasher that is to tall or comes up above the drawer when you start the dishwasher it has a lid that comes down and if it does not seal you will get an f1 code and it will require a tech.
1 Related Answer
Anonymous
  • 1073 Answers
  • Posted on Apr 10, 2008
SOURCE: i have a kenmore dishwasher.
disasemble the pump housing and remove the debris that are located in the housing, not enough pump pressure to spin the spray arms to desolve the detergent
2answers
Accidentally put normal dishwashing liquid in the rinse aid space
The amount you have put in although not good is not too serious.You can try putting nothing in dispenser for a few washes and see how that goes.If you are using the 3 or 4 in one tablets you should not need to dose with rinse aid or salt as it is in the tablets.
Hope that helps.
Extra suds due to liquid soap in the machine overflowing. How do I drain it?
This is strange. Are you using an electric dishwasher liquid soap, OR are you using a dish soap that you manually use to wash dishes?
REGULAR dish soap liquid that is not specifically made for dishwashers creates a foamy suds with lots of bubbles that will in fact bubble out of your dishwasher. on the other hand. Electric Dishwasher detergent will NOT create foamy suds with lots of bubbles.
Switch your soap. The next cycle any residue suds or soap will be gone as long as you use the proper liquid detergent. I would also recommend using a rinse agent which further helps break down and rinse off residue.
I recently bought a different type of dishwashing detergent for my Frigidare dishwasher and my dishes look as if they have not been rinsed. They cycled all the way through the drying cycle so the detergent...
the best way to use your dishwasher is the way it was designed.
if your unit has a compartment for jet dry or rinse agent then you should add and fill that compartment with rinse aid. try not to buy soap with any extra like soap with jet dry or shine plus . because when you fdo that sometimes customer think that they dont need rinse agent . big mistake. rinse agent is deposited at a certain time in the cycle. diod you know that is you use lets say jet dry and a soap with shine plus or rinse aid in soap the machine can over suds? as a tech trust me i have seen it.let me know if i was helpful. drop a 4thumbs up post
Feb 28, 2010 • Dishwashers
1helpful
I just moved into a house with a Roper dishwasher. I could not find a users manual that would tell me what type of soap that could be used in this machine (powder or liquid?) and where to put the soap in...
The dishwasher will clean best if you use a name brand powder. As you look at the inside of the door of your dishwasher, you should find some sort of dispenser cup or tray, with a lidd that closes some how.
You do not need to fill the cup(s) full of powder to get clean dishes.
Also, you should have a rinse aid dispenser that should be refilled fairly often.
Aug 05, 2009 • Dishwashers
2answers
GE Nautilus
Hi Lisa in AR
I'm Harvey the Master Plumber.
Your question is: Why won't your soap dispense anymore?
Yes, you're correct. This is best looked at by a local pro! You may want to compare the cost of repairing a six year old dishwasher now verses temporarily putting the soap in manually till you can find a good price on a new one. Personally, I loath throwing good money after bad so I go for the latter and we're coming up on the holiday discount season.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Whirlpool gold dishwasher
Did you use dishwasher detergent? Liquid soap that you use in the sink for dishes will foam and flood the floor. If it is the machine I need to know if it won't stop filling or if it leaks while the machine is running.
Jul 04, 2008 • Dishwashers
1helpful
I have a kenmore dishwasher. the soap dispenser lid was not opening and releasing the soap, now the lid is opening but it's leaving the soap in the dipenser. have used the pellets that contains the liquid...
Apr 09, 2008 • Dishwashers
1helpful
2answers
Zanussi ls9
write to me if you need the manual.as for the soap the dishwasher uses only liquid professional soap and you must connect it inside the tank . there is also a blue pipe for the rinse aid detergent
let me know if you need anything else
Soap does not desolve
check that the spray arms are turning and that the holes in them are not clogged, if you line them up pointing towards the front let the machine fill then as it starts to wash open the door and you should see the arms slowing down, if they are okay then check the water level which should just lap the filter at the bottom
Dishwasher ran with wrong soap
add some salt in the cabinet and a bit of water. salt acts as a foam suppressant
Top Fisher and Paykel Dishwashers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
