My Desktop WILL NOT Turn ON. POWER SUPPLY LED IS LIGHTS AND CHECKED POWER SUPPLY WITH ANOTHER HP DESK TOP. FRONT POWER SWITCH IS OK AND IT CHECKED WITH OHM METER. BUT BOTH LEDS ARE OFF. REPLACED LITHIUM BATTERY CR2032 WITH NEW ONE, BUT WILL NOT POWER UP WHEN PLUGGED IN.
I edit your post. no PC stated, HP what model please.
I is a desktop.
you turn on PC and PC is dead, no fans , no sounds from PC
no beep codes, no LED caps lock key blink codes.
no text, no logo's on screen ever (gee the monitors even sign on and say no signal if the monitor is good and PC dead. does it?
what monitor is there, name and model.
I will answer for DEAD PC only. (monitor tests ok on other PC)
generic desktops, only
the PSU tests are here, takes paper click and 15 minutes work.
see jumper tests
http://www.pcdied.com/power.html#Jumper
Try again with the model number
ditto. real model
the service tag, is there to read.
see this, its the service tag
line 1,3,5 tell the expert at least what it has inside when new.
my wild guess, bad ram
you can bench test any PSU. or frame test it in case with 1 jumper wire.
showing you see PSU runs.
do the jumper test.
SOURCE: UPS TRIPS AFTER 30 SECONDS
dear, This problam is related to battery and i am sure your battery is faulty pls replace it.
SOURCE: HP altec lansing Pavillon DV 6700 not powering
I am sorry to say that this is likely to be motherboard damage. The only other possibility is the the Power jack on the laptop itself is loose or shorted.
Either way.. You need a qualified repair.
The safe bet is a new motherboard.
sincerely,
Sagacious1
SOURCE: Gateway MA7 (MX6955) Will not boot up, or power
hold on i have a gateway here let me see if it does or not.nope mine works without battery i had to push the power button a couple times but it fired up.could be your MB
SOURCE: York Diamond 80 Furnace: blows cold air after
There may be more than 1 limit switch. Look at the wiring diagram and follow it to all switches. Or jump out the complete circuit.
