1. Set the tension on the bobbin.
2. When you thread the upper thread do it with the pressure foot up.
While you are threading give slight tugs to check for snags. If there are snugs you must fix them.
3. Put the pressure foot down and adjust the tension to four. Give a tug. It should have tension but still allow the thread to flow.
(Look at your thread and look for fuzz on the sides. This indicates a bad quality thread. A good choice is embroidery.)
4. Make sure the needle has been installed going the right direction. Usually flat to the front or to the right side.
5. Turn the hand wheel while you hold the needle thread to the front.
The bobbin thread should come above the throat plate in about one turn.
NOW YOU SHOULD BE ABLE TO SEW.
LOOK AT INFORMATION ABOUT BOBBIN TENSION.
