I started the program with no issues, then halfway through the first core of Italian level one, the program says it encountered a small problem then my microphone fails to work. When I try to recalibrate the software doesn't even recognize its existence nor the built-in microphone in my laptop (Mac G3 pismo).
Webcam Audio Getting sound to broadcast with streaming video using a webcam requires a few components to work in unison. Because most webcams do not have a microphone built in, you will need to buy a microphone for your computer or locate your microphone input if you have one built in (some laptops have these). The audio and video are two separate functions and must be diagnosed as such. b> Webcam Software b> If you have a webcam set up correctly and you are streaming video, then you are already halfway there. This details only how to make the sound work, so please refer to an article related to webcam video if you do not have that working already. The webcam audio and video both communicate with your computer via your webcam's software application. Due to this, you will find that there are settings specific to your webcam software for sound. Because there are various software applications that can act as an interface for your webcam, you will want to do a product-specific search on the Internet for your application's settings. Most often you will find the settings for sounds under Tools or Settings, then choosing Options or Preferences. Regardless of the application that you are using to broadcast your webcam video, you will need to ensure that your microphone is plugged into the "Microphone In" jack on your computer or laptop. The microphone input jack is commonly colored pink. b> Microphone Connection b> With your microphone plugged into the "Microphone In" audio jack, test the audio inside your webcam's software application. Most webcam applications allow you test your microphone by reading a sentence and watching a graph move as you speak. If you see this happening, then you have correctly hooked up your microphone. If you have a Windows PC you should also see if your computer recognizes your microphone by clicking on "Start" > "Settings" > "Control Panel" > "Sounds and Audio Devices." Under the "Audio" tab you will find a section for "Sound Recording." From there you can select or change your "Default Device." b> Hardware Troubleshooting b> In the event that your microphone is not recognized by your computer, continue hardware troubleshooting by contacting your computer's support staff. With a properly connected microphone and some minor adjustments in your webcam's software application, you should be broadcasting audio with your video in no time. Hope this helps.
<p>Line-in <br />
<p>1. Buy a software package for recording music, if your
budget allows. Recording music software is specifically designed for recording
musical instruments formed. He cannot offer features found in common software
audio. Alternatively, an audio recording program for free to get the music
recording software than your needs and budget. <br />
<p><br />
<p>2. Buying a guitar cable to your computer if you use an
electric guitar. Connect the larger end of your guitar amplifier and the small
end into the computer microphone / line-in. <br />
<p><br />
<p>3. For an external microphone when a traditional guitar.
Plug the microphone into the computer microphone / line-in. A stereo microphone
is a natural sounding audio file, due to the dual microphones. <br />
<p><br />
<p>4. Open your audio recording program, which recognizes the
device connected to ensure the microphone / line-in. Pull the cord, again if it
does not recognize the device. Change the settings for the recording program to
your needs to adapt, you can file type for quality change, and the recording is
mono or stereo and audio level. Press the Record button, then started playing
guitar. <br />
<p><br />
<p>5. Press the "Stop" button when you finish the
game. Some programs can automatically be prompted to save the file; others may
be the audio file first. Press "control" and saving "S", if
not prompted. <br />
<p><br />
<p>Digital recorder <br />
<p>1. Buy a stand-alone digital recorder, if you do not want a
guitar cable or an external microphone. A stand-alone digital recorder is small
enough to fit in your pocket and can be placed anywhere without the need
hampered by a cable. <br />
<p><br />
<p>2. Set the digital recorder on a flat surface. Press the
record button. <br />
<p><br />
<p>3. Press the digital recorder, "Stop" when
finished. Connect the recorder to the computer with data cable. Open the device
by clicking on "Start" then "Computer" and double click on
the recorder in the "Removable Devices". Copy the file from the
recorder to your computer. Turn off the burner when you are ready to save
battery power.<br />
Firstly all lines have to be timed. Then they will scroll. Other issue is the microphone is 16 Bit and we use mostly 32 and 64 bit file names as well as allowed characters within a page. 16 bit dos is limited characters specially comma or ( ) [ ] } : # $ so on will not work with this mic. Convert what doesn't work with FileEncConverter (available on web) and they will work. This program removes what mic can't handle.. Good luck
go to the web page for the manufacturer of the microphone
find a down load for that model suitable for mac operating system and down load the driver or software
Page fault is a core level issue, Really it is time to consider hardware and OS upgrades. Windows 98 support in 2006, because the issues were redsigned in newer OS. and now you are about 4 upgrades behind.
Look at the error logs in Windows and I presume that you will see tons of issues. UPGRADE.
Turn all your levels down.. ALL of Them. does that help? if the noise stops, proceed to slowly turn each volume up some one at a time. that may help figure what is causing the problem. if not could be small programming issue between the mic and the input program. i would look threw your settings menu for the recording software. see if there are any input or recording preferences/settings. i don't know if the mic came with setup software or a manual. may help alot. probably just one little setting off. learning will only help in the long run
I solved by going to Control Panel, Sound, Recording, then click on your mic and click on Configure, and then Set up microphone... Thats probably going to fix your problem... That easy... xD
How can you reinstall and install the java software if it does'nt exist in your system,right? Read the information below which I researched for you. This addresses you in your problem. Don't forget to rate me..:-) Thanks.. Error: 25099 during Java installation
This article applies to:
Platform(s): Windows 2000 , Windows XP , Vista , Windows 2003
Browser(s): All Browsers
Java version(s): 6.0 , 6u10+
SYMPTOMS
While Java installation is in progress, a message box with the following error is displayed:
Error 25099. Unzipping core files failed.
CAUSE
The actual root cause of this issue is still under investigation. Error 25099 indicates that the Java installation process has failed.
WORKAROUND
Step 1 : Completely delete content of the following directory: C:\Program Files\Java\jre6\ (or alternate directory if you chose a non-default install location)
Step 2 : If Step 1 has permission issues due to files being locked or in use, restart your system
Step 3 : Now, completely delete content of the following directory: C:\Program Files\Java\jre6\
Make sure that your device is set as your default device by making sure that there is a green check mark next to the device. If not, right click and select "set as default device" (or something like that... I have vista and not win7)
If that does not work, right click on the headphones and go to "Properties" then go and under the "General" tab, change the name of the device to "Microphone HS" For some reason, Rosetta Stone does not recognize the headset unless it has the word "Microphone" in its name... Kinda stupid if you ask me. Hope that helps...
Rt. click the volume control icon from your notification area or the control panel and choose advance settings and make sure the microphone line in level is not at zero. Open your recording program (like sound recorder from Accessories>Entertainment) and you should be able to record sound input from your microphone. If you're still having trouble, follow the steps here or here (http://www.logicaltips.com/LPMArticle.asp?ID=610) Also be aware that there's a great freeware recorder available online called Audacity available from here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
