Hello
I install an system W2000 with board AVID products,. When tue system detect the hardwar with the board Avid I get a blue screen with message ''The ACPI BIOS in this system is not fully compliant with the ACPI spécification''. They preconise to install the update of Bios.
The computer is a compaq evo w8000.
Where can i get this update and the procedure to put it?
Thanks
W8000 a very old PC not supported by HP.
windows 2000 support ended like 15 years ago.. W2k. is gone. w2k only runs on very old pcs with very old ACPI
(power controls is that)
this PC is only supported with XP
never 2000.
HP tells you that if you looked.
park the 2000 disk or use it as frezzbee. IMO
https://support.hp.com/us-en/drivers/selfservice/compaq-evo-workstation-w8000/322279
id get w7 disk and use that, it might work.
but will cost you a license from MS,
about 5 times the value of w8000
why not just go here, and get used $20 w7 pc
save a bundle of case and grief messing with any legacy junk....avoid legacy junk and win.
http://www.pcdied.com/cheaper.html
a usa answers.... always...
windows 2000
nobody use it , do you see anyone using w2k
no.
windows 2000 only runs on legacy PCs
period.
SOURCE: Hard disk space
Check on the HP website for BIOS updates and Firmware updates for your raid controller. This sounds very odd that there is a 28GB limitation on drive size? What size drives are in there now? They usually step up in size like 9GB, 18GB, 36GB, 72GB, etc.... Your IT guy maybe misinformed.
SOURCE: acpi complaint - reg
Reset you BIOS to it's default. Hit Del/F1/F2/F10 or whatever key the machine prompts you when it first boots to get into system setup. Then pole around to find a restore to defaults option.
Or you may in fact have to upgrade the BIOS, what kind of system or motherboard to you have?
I have located some info on this board. it was released as a "Medion" board
there is some BIOS and driver stuff available HERE
http://www.medionusa.com/ and select customer care.. you need the exat model no or the serial no of the PC to continue though.
Also http://www.treiber.de/ may me of assistance as I think they are the real manufacturer but as I cannot read German I cant really be sure. they have the link to Medion on their webpage...
HIH and please post back results
SOURCE: bios for adapter 0 is not installed 4600 poweredge
There are problem with Operating System ,It has been corrupted so pls re-install the operating system .
SOURCE: bios
Once the operating system is installed its quite difficult to create a partition . One way is to create is via a Third Party software like Partition Magic.
