Question about Razor Scooters Cruiser Scooter
Can't fold down a razor cruiser for storage, how do you do it?
The lever seems stuck for me to fold the cruiser scooter, how do i do this?
  • 1 more comment
  • amy8584 May 02, 2009
    Got it done!
    thanks a bunch
  • inxsrocker May 12, 2009
    I don't get what you're talking about.
  • danh
    danh Sep 08, 2014
    so how do you do it
  • 40 Answers
There are two steps to release the handle for folding. Pressing the thumb lever is one step and the other is lifting the handle bracket up. The handle is held in place by two metal pins (one on each side of the handle bracket). The pins slip down into a notch on the scooters bottom bracket. If the lever won't push, you will need to spray some WD-40 or other lubricant on it as they do tend to rust. Once you have the thumb lever where it can be pressed down, you can then lift the handle out of the bottom bracket. This may be stuck as well so a light tap with a hammer may be necessary to release the handle.
Posted on May 01, 2009
SOURCE:
The manuel lever for pushing is stuck
If it is stuck, the lever may have corrosion and need some oil on the lever by the brake. Be careful not to get any oil on the brake pad or the parking brake will not work very well. After a little oil work the brake back and forth until it moves freely. Scooter Doctor App
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Apr 06, 2016 | Health & Beauty
How do you fold the Monster High Scooter?
At the bottom of the red section of the scooter where it meets the pad where your child stands while riding it there should be some sort of lever that you push or pull that will allow the scooters handle bars to fold down for storage or travel. Good luck :)
Sep 29, 2012 | Toys
Jamis Boss Cruiser cable and shifter issues.
Most likely the shifter and levers are not the problem, rather the cables are probably corroded and need to be replaced.
replace grip shift cable Google Search
replace rear brake cable upright bars Google Search
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Dec 29, 2017 | Jamis Boss Cruiser Coaster
My scooter which is a Fold and Go keeps stopping suddenly and battery becomes dead, checked all wiring in battery it seems fine, what other problem could it be?
I had this problem with my caddy. I had to send it to Florida,UPS, and they fixed the problem. It had to do with the tiller connections. Worked great after.
Aug 09, 2010 | ElectroVoice EV Rider FTCA020 Caddy Fold N...
I cant fold the scooter down to fit into a suitcase
There are 3 things that can fold.
The handlebars collapse from the lever on top of the handle bar, that allows each handle to pull out.
The lever at the base of the handlebar allows it to retract.
And the lever at the base of the steering allows the body to fold against the steering shaft.
May 28, 2010 | Razor 'A' Scooter-Clear
HOW DO YOU UNFOLD A SCOOTER
This is very simple really, just find a lever at the base of the scooter and pull up, while also pulling the handlebars up. Sometime the lever has a lock that you have to pull or unscrew.
Nov 14, 2009 | MGA Entertainment Bratz Musical Stars Fold...
My battery pack on my fold n go has a short and
hi, ok now you need to check your wiring within the battery pack ,
If there are two batteries, you need to make sure that negative wire of one battery connects to the positive of the other battery,
now use the postiive and negative battery connections to connect to the scooter , that will give you your 24volts,
battery 1 connects battery 2
== 24Volts
use the + of battery 1 & - of battery 2 to connect to the scooter.
Regards
GeWiz.
Oct 29, 2009 | ElectroVoice EV Rider FTCA020 Caddy Fold N...
Rear seat jammed in the up position
Try the lever on the side of the seat next to the door.
May 03, 2009 | 2002 Mitsubishi Montero
Razor Scooters  Cruiser Scooter Logo
6,700 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
William Erickson
Are you a Razor Toy Expert? Answer questions, earn points and help others
