Have to re-start to get it to finish.
The same thing happened to our washer and a friend told us to take off panel below door and there's a opening that's covered with a circular plastic cover, open manually and remove all the junk that's accumulated from all washes, careful it may leak a great deal of water! Try that if anything else, unless you've already had it serviced!
I'm looking to try and solve yet another issue with the same washer...
Stops with 29 minutes left, have to continue to re-start
my washer stops at 19 min and then when it goes into a spin it says it is rinsing and takes for ever to finish any suggestions
dcritchfield Rocks! I had the same problem and their suggestion worked. Watch out, lots of water, get a large baking pan and be prepared to sift through a fist full of pocket parts!
I had the same problem and your solution eliminated the problem. I will do it at least once a year as a maintenance process.
Thanks
Eddy, Boucherville, Qc. Canada
