I have facing problem of my hard disk 320GB Caviar Blue no Detection no Current. it was Dead During installing pc Windows.
WARNING Before you
start troubleshooting remember that you are dealing with electricity that can
KILL.
http://www.kitchentablecomputers.com/static.php
- rules
Only work inside the computer case when the power has been
switched off and disconnected. Never open the power source.
Some of the below steps
recommend removing physical parts within the computer.
While in the computer it is
highly recommend that you be aware of ESD and its potential hazards
Test all leads that attach to your hard drive power and data
cables IDE ,SATA
the leads from your
MOTHERBOARD TO YOUR HARD DRIVE
make sure they have a secure dust free connections and are not faulty or
just replace them they could be faulty
Make sure all leads that
are attached to your dvd \ cd floppy drives have secure connections and are not
faulty or just replace them they could be faulty.
Computers need power and
data to travel through every working device to continue its cycle and have an
end so any faulty leads will end up with a computer error.
Even something as small as
a faulty electrical or fan lead can cause you problems
Motherboard and a Hard Drive any leads between them will
fail before your motherboard or your hard drive if its a flat ribbon 40 pin
type IDE replace it this will be the first to fail.
Check all electrical power input and extensions
make sure they are securely seated even the cd/dvd floppy drives need to have
current go through make sure these drives are working
Could be a problem with the Hard Drive or the Hard drives
PCB
http://www.onepcbsolution.com/
http://www.youtube.com/watch?v=du0Qd_3wFWM
SOURCE: PC stopped reading Cavalry External HardDrive
i have a feeling its not the hard drive thats bad i think it sounds like the case .
you can try buying another case and transfering the hard drive to it the case is around $20.00
SOURCE: samsung sata hard disk detection problem while windows setup
Check your BIOS. There's a setting there to change the Drive controller which allows the SATA drive to be recognized. I believe when I did it I had to change the RAID setting (even though I wasn't using RAID).
SOURCE: wd external hard disk and lenovo s10 notebook problem
this is due to virus or malware. it is possible that it is present in hard disk. whenever you tries to open the file, at that time the virus get activated and creats error.........for this you need to install the latest updated antivirus. but some antivirus are worthless. so i recommend you to use quickheal antivirus and scan the hard disk
SOURCE: WD Caviar SE16 WD3200AAKS 320GB 7200 not recognized at install
Windows XP does not have built in SATA drivers. You will need to download the XP drivers from Western Digital's website and install before the computer will allow you to format and use your new drive. Hope this helps.
SOURCE: when I connect my seagate expansion external hard
either an issue with the hard disk, or with your system. Make sure the hard disk has power on it and if you can, it would help to test it on another computer to confirm if it works. If you have ruled out the possibility that it is the hard disk, next is review if the hard disk has system requirements you need to meet. If the requirements are met by your XP SP2 machine, you may try updating the computer's system software/chipset drivers and a BIOS update may also be necessary.
