Computers & Internet Logo
Anonymous Posted on Jul 26, 2013
Measurement tool bar is stuck at the bottom of the screen
1 Related Answer
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Jan 26, 2010
SOURCE: save as screen will not expand to allow use of
OK increase ya screen resolution to a higher one say 1024 x 768 32 bit. Right click desktop go to screen resolution tab and change.it to a bigger screen.
Make google your homepage
In Internet Explorer. Go to Tools in the upper left hand corner, then in that box click internet options at the bottom. A box will pop open.
In the top of that box will be an address. Delete it and type www.google.com then hit ok at the bottom. Do not hit apply, hit ok. Should be good to go. Open a new webpage to make sure it stuck.
As a side note, if you don't see the line on top of your screen that says file, view, favorites, tools, and help do this...right click with your mouse on the top of the page ABOVE (not in) the address bar and make sure "menu bar" is checked.
Good Luck
Make google my homepage
Good Luck
Dec 07, 2013 • google.com
WANT TO MAKE ASK MY HOMEPAGE
In the top of that box will be an address. Delete it and type www.ask.com then hit ok at the bottom. Do not hit apply, hit ok. Should be good to go. Open a new webpage to make sure it stuck.
Good Luck
2helpful
3answers
Tool bar moved t right and is large
Right click on the task bar (I assume you mean the bar that is typically at the bottom of your desktop?)
Make sure "Lock the Task bar" is not checked
Click on the border of the task bar
drag directly from where you clicked to the bottom
Adjust height accordingly
Length of bar on a Stihl 015 chain saw
measure from the very front edge of the bar back to the gripper teeth
Missing the tool bar on document page
Maybe I can help you. I' m not sure what program you're using but a typical place to find the on/ off toggle for toolbars is in the "VIEW" tab usually at the top of your screen in a word processing program such as Microsoft Word.
There you shoud see your options under 'TOOLBARS"
Let me know if this works for you
Tool bar missing on computer
Assuming "tool bar" = Task bar
and your OS = XP
It's possible your task bar is hidden on bottom
just drag the bottom line of your screen upward
Check if your task bar properties are set to "hide the task bar" remove the setting
"Windows Expolorer in not responding" on Toshiba with Vista
just go to start and then i believe it acessories system tools then to system restore just go to a time where it was working
Top Quark Computers & Internet Experts
 Grubhead
Grubhead
Larry Ng
Larry Ng
ADMIN Eric
ADMIN Eric
Are you a Quark Computer and Internet Expert? Answer questions, earn points and help others
