2001 Nissan Quest Logo
Posted on Mar 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replace driver side mirror on 2001 Nissan Quest
I have purcahsed a replacement driver side mirror for my 2001 Nissan Quest. Is there step by step instructions on how to replave the mirror?
  • 1 more comment
  • cmhughes Mar 31, 2009
    I am replacing the entire mirror fixture.
  • Anonymous May 11, 2010
    are you replacing just the mirror, (if so see: www.burcoinc.com goto 'redi cut' then 'instructions') OR are you replacing the entire mirror head assembly?
    is it just the glass part of the mirror or is it the whole mirror with the fixture ?
gerry bissi
Level 3:
  • Nissan Master 4,390 Answers
  • Posted on Apr 24, 2009
gerry bissi
Nissan Master
Level 3:
Answers
4390
Questions
Helped
3060145
Points
11499
SECTION 501-09: Rear View Mirrors 2001 Villager Workshop Manual REMOVAL AND INSTALLATION Mirror —Exterior Rear View Removal
  1. Remove the front door trim panel. For additional information, refer to Section 501-05 .
  1. Remove the upper speaker.
    1. Disconnect the electrical connector.
    1. Remove the bolts.
    1. Remove the speaker.
  1. Position the watershield aside.
  1. Remove the exterior rear view mirror access panel.
  1. Disconnect the exterior rear view mirror electrical connectors.
    • Release the wiring harness locator.
  1. Remove the exterior rear view mirror.
    • Remove the bolts.
    • Feed the wiring harness through the door opening.
5 Related Answers
Anonymous
  • 375 Answers
  • Posted on Jun 24, 2008
SOURCE: need to replace drivers side mirror
not so difficult , there should be a piece of trim straight in from mirror on inside of door, remove trim behind should be nuts holding mirror on.
Try partstrain.com they sell aftermarket replacement parts, mirrors look like origionals but alot cheaper
Anonymous
  • 334 Answers
  • Posted on Nov 25, 2008
SOURCE: 2001 Infiniti QX4 low beam bulb replacement instructions
Look directly behind the headlight box if there is a rubber sleave covering the plug take it off. Unplug the wires from the bulb, there may be a saftey clip you will have to pry up to get it off.after you get the plug off the bulb holder should twist counterclockwise then it will pull right off.When you change the bulb just remember to wipe your body oil off the bulb before attaching it back into the headlight box. Then plug it back in and your in business. The high beam has three wires and the low beam has two wires. The bulb will have to be the right one.
God Bless You Greg
gerry bissi
  • 4390 Answers
  • Posted on Jun 17, 2009
SOURCE: NEED TO REPLACE ALTERNATOR MYSELF
here's 96. should be the same. Be very careful not to overtighten any of the belts or you can break the snout off the crankshaft and ruin you engine.
Section 14-02: Generator, Integral Regulator — Internal Fan and Regulator Type 1996 Villager Workshop Manual
REMOVAL AND INSTALLATION Generator Removal
  1. Disconnect the battery ground cable (14301).
  1. Raise and support the vehicle.
  1. Remove the five engine and transmission splash shield bolts and two engine and transmission splash shield screws.
  1. Remove the RH engine and transmission splash shield (6775).
  1. Remove the wire harness bracket bolt.
  1. Remove the B-terminal insulator boot.
  1. Disconnect the generator electrical connector from the generator (GEN) (10346).
  1. Remove the ground wire nut from the generator and position the ground wire aside.
  1. Remove the B-terminal nut from the generator and position the B-terminal wire aside.
  1. Loosen the inner and outer generator-to-bracket bolts.
  1. Loosen the generator locking bolt.
  1. Loosen the generator adjustment bolt.
  1. Remove the drive belt (8620) from the generator pulley (10344).
  1. Remove the generator locking bolt and washer.
  1. Remove the inner generator-to-bracket bolt and the two washers.
  1. Remove the outer generator-to-bracket bolt and the two washers.
  1. Remove the generator.
Installation
To install, reverse the removal procedure. Tighten the inner generator-to-bracket bolt to 23-26 Nm (17-19 lb-ft). Tighten the outer generator-to-bracket bolt to 23-26 Nm (17-19 lb-ft). Tighten the generator locking bolt to 16-20 Nm (12-15 lb-ft). Adjust the drive belt very carefully. Refer to Section 03-05 for the procedure.
Anonymous
  • 1986 Answers
  • Posted on Sep 29, 2009
SOURCE: Replace passenger side electric mirror
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Then you can access the bolts that secure the mirror onto the door
Anonymous
  • 1986 Answers
SOURCE: replace passenger side mirror on 2008 Impala
Driver side power window stuck in down position - Nissan Quest 2001
I HAD THE SAME PROBLEM DIAGNOSE MOTOR OR SWICH MOSTLY BAD SWICH ,BUY ON LINE EASY TO CHANGE
2helpful
2answers
Need to replace driver's side mirror-1999 Nissan Quest
directly behind the mirror on the inside of the door there will be a plastic triangular cover, this cover will unclip with a little bit of prying with a flat blade.
Behind the cover you will see a few holes in the panel, in at least 3 of those holes you will see bolt heads, thes have to be removed but before you do there is a multi wire plug that you need to seperate if you have electric mirrors.
once the bolts are removed you should be able to remove the mirror
1helpful
The driver side window of our Nissan Quest Van won't go up. What trouble shooting tips do you recommend?
1st need check fuses for windows next check switch capability by switching up and down see if window will respond next check power to switch next check power to window motor if all ok replace window motor don't forget to check window rail make sure not jaming
95 nissan quest front passenger side power window does
driver side switch is not working replace it
4helpful
I have also broke off my 2001 Nissan Quest sliding door handle on the driver side. Also the sliding door cannot be opened from interior... Any help is appreciated... Thanks
the child lock rod may have been extended...
open the driver side door, and with a skinny finger, push that child lock rod back in towards the rear of the sliding door
use the passenger side as reference
once you pushed it in, you can now open it from the inside handle
2helpful
Driver side motorized mirror on auto needs to be replaced
the whole asssembly or just the mirror glass?
1helpful
Replacing Nissan Altima 1998 passenger mirror
to replace it you have to open up the door take off the little plactic piece in the corner of the door,, then there is going to be 3 screws that you have to remove in order to remove the old one, just do the steps in reverse to replace the new mirror, i just had the same issue, but on the driver side.. good luck
1helpful
I need the location of fuel filter
Under hood, driver side, rear engine area, passenger side of master cylinder, mounted on firewall
2001 Nissan Quest - Broken Exterior Sliding Door Handle
you can do this. you have to remove inside trim panel for access. if you still need to do, I will send you repair steps. let me know
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
