Water comes out below the pump area when running. there are three open slots on the pump housing where the water comes out.itook the pump apart and found 3 orings and washers. what needs to be replaced?
SOURCE: We have a leak on the pump around the manafold and
Usually when water is leaking from in between the manifold and the oil side of the pump, the high and low pressure seals (a.k.a. packings) are worn out.
http://schematicsdiagram.blogspot.com/2011/12/transmission-fluid-gets-into-radiator.html
The plastic housing which
goes to the upper radiator hose is cracked and leaking?
http://schematicsdiagram.blogspot.com/2011/12/plastic-housing-which-goes-to-upper.html
Radiator leaking?
http://repairhelpcenter.blogspot.com/2011/12/radiator-leaking.html
--------Car water leak around the
Starter area and Bell Housing?
http://schematicsdiagram.blogspot.com/2011/12/car-water-leak-around-starter-area-and.html
--------Leaking head gaskets?
http://schematicsdiagram.blogspot.com/2011/12/leaking-head-gaskets.html
---------This will help.Thanks.
