Press button B for 2 seconds and second hand will move to show current time zone; 12=London, 1=Berlin, 2= Helsinki. press button A to cycle through time zones till you get the zone you want, then press B to confirm. Summer and Winter are changed automatically, contrary to the previous rubbish....I mean answer!
Just draw the short hand to the right value. (The short hand is normally frictionally coupled to the axis, and that action would not cause any problem with the clock function.)
But DON'T move the long hand!
QUICKSTART - SET THE TIME 1. Push the bottom right hand button until the mode hand indicator points to TME. 2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position. 3. Select the time zone on the digital display by pressing the upper right button or the lower left button. 4. Pull the bottom right button out one click. The bottom part of the digital display will start flashing. Press the bottom left button to adjust for daylight saving time. 5. Press the upper right button. You will see the seconds flashing on the lower half of the digital display. Press the lower left button to reset the seconds to 00. 6. Press the upper right button. You will see the minutes flashing. Press the lower left button to set the minutes to your current time. 7. Press the upper right button. You will see the hours flashing. Press the lower left button to set the hours to your current time. 8. Press the upper right button. You will see 12H or 24H flashing. Press the lower left button to switch between 12 hour and 24 hour. 9. Push the lower right button back in.
SET THE CALENDAR 1. Push the bottom right hand button until the mode hand indicator points to CAL. 2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position. 3. Select the time zone on the digital display by pressing the upper right button or the lower left button. 4. Pull the bottom right button out one click. You will see the month flashing on the digital display. Press the lower left button to change the month. 5. Press the upper right button and the date will begin flashing. Press the lower left button to change the date. 6. Press the upper right button. You will see the year flashing. Press the lower left button to change the year. 7. Push the lower right button back in.
SET THE ALARMS 1. Push the bottom right hand button until the mode hand indicator points to AL1, AL2 or AL3. 2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position. 3. Select the time zone on the digital display by pressing the upper right button or the lower left button. 4. Pull the lower right button out one click. You will see ON or OF flashing on the digital display. Press the lower left button to turn the alarm on or off. 5. Press the upper right button. You will see the hours flashing. Press the lower left button to change the hour. 6. Press the upper right button. You will see the minutes flashing. Press the lower left button to change the minutes. 7. Push the lower right button back in.
SET THE TIMEZONE 1. Setting the time zones allows you to add or remove cities on the digital display or switch between daylight saving and standard time. Begin by pressing the lower right button to move the mode hand indicator to SET mode on the bottom dial. 2. If the hour or minute hands are obscuring the digital display, press and hold the upper left button for three seconds. This will cause the hour and minute hand to retract to the 12 O’clock position. 3. Now pull the lower right button out one click. You will see the digital display flashing. Press the upper left button to select SET to display the city or OFF to not display the city. Press the lower left button to turn summer time on or off. Summer time is indicated on the lower part of the digital display. Daylight savings time must be manually set for each city. 4. Pressing the upper right button will allow you to scroll through all the cities. After setting, push the lower right button back in.
USING THE TIMER 1. Press the lower right button to move the mode hand indicator to TMR mode on the mode dial. 2. If the hour or minute hands are obscuring the digital display, press and hold the upper left button for three seconds. This will cause the hour and minute hand to retract to the 12 O’clock position. 3. Pull the lower right button out one click. You will see the minutes flashing in the digital display. Change the minutes by pressing the lower left button. Once you have set the minutes on the timer, push the lower right button back in. 4. Pressing the upper right button starts and stops the timer. 5. Press the lower left button when the timer is stopped to reset the timer to its initial preset time.
USING THE CHRONOGRAPH 1. To use the chronograph press the lower right button to move the mode indicator hand to CHR mode on the mode dial. 2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position. 3 .To start or stop the chronograph press the upper right button. If you press the lower left button it will display the split time for 10 seconds. 4. When the chronograph is stopped press the lower left button to reset back to zero.
SET THE TIME ZONE 1. Setting the time zones allows you to add or remove cities on the digital display or switch between daylight saving and standard time. Begin by pressing the lower right button to move the mode indicator hand to SET mode on the bottom dial. 2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position. 3. Pull the lower right button out one click. You will see the digital display flashing. Press the upper left button to select SET to display the city or OFF to not display the city. Press the lower left button to turn summer time on or off. Summer time is indicated on the lower part of the digital display. Daylight savings time must be manually set for each city.. 4. Pressing the upper right button will allow you to scroll through all the cities. After setting, Push the lower right button back in one click.
Set in correct order:
1) Hand Home Position
2) Digital Time Set
1) Hand Home Position:
Press and hold A and B for 5 seconds, Press A to move Second Hand to 12: position: (if not there). Press B to enter Hour/Min set mode. Press A to move both hands to 12: position. Hold A to move hands fast, Press A again to stop hands. All 3 hands are now at 12' oclock.
Press B to exit Hand Home Position mode and enter Timekeeping Mode.
2) Digital Time Set: (hands will self set when done)
Press and hold B for 5 seconds to enter setting mode.
Press A to advance current item or scroll through choices. Press B to set item and advance to next item.
<Order of Items to Set>
GMT Differential -> Daylight Savings auto/on/off -> Seconds -> Hour -> Minutes -> Year -> Month -> Day -> Day of week language -> Auto receive -> (back to Timekeeping Mode).
<Setting each Item>
GMT Differential: Press A untill your time zone is reached (E=eastern, C=central, M=mountain, P=pacific). Press B to set (advances to next item).
Daylight Savings: Press A untill desired DST mode is reached: ("At" auto, "On" after spring change, "Of" after fall change) Press B to set (advances to next item).
Repeat to set: Seconds (resets to :00), Hour, Minutes, Year, Month, Day, Day of Week Language, and Auto Receive (on/off).
For each item, Press A to advance, and B to set.
Pressing B to set last item exits Setting Mode and enters Timekeeping Mode. Hands advance to current time.
