Lands Phones Logo
Anonymous Posted on Mar 31, 2009
Trying to cancel a command
On my screen it's say: Appel reçu
APPELS
I'm trying to cancell that it means in english : receving call
CALLS
Phone is Meridian M7310 nortern telecom
Anonymous
Level 2:
Champion:
  • Expert 211 Answers
  • Posted on Apr 01, 2009
Anonymous
Expert
Level 2:
Champion:
Answers
211
Questions
0
Helped
75155
Points
371
You can purchase a manual for your system for about 10 dollars
Email your system model number to sales at aaa-avad.com for further instructions
CANCEL DG ON MY AVAYA 9800
I am not sure why you would want to disable G on the phone. G specifies that you are part of a Hunt Group. To be taken off the hunt group, please contact your phone system administrator. The "D" stands for diverting (forwarding) calls, which means forward unconditional is enabled. To cancel all forwarding, Dial *00
2helpful
I don't know what is the password of call barring belongs my cell phone SGH-L760
hi,
Before you can activate these barring services you will need a barring code from your service provider. Call Barring can not be activated if Call Forwarding diverts are already in use.
To Activate: * 330 * BARRING CODE # [SEND]
To Cancel: # 330 * BARRING CODE # [SEND]
To Check: * # 330 # [SEND]
All Outgoing Calls
To Activate: * 333 * BARRING CODE # [SEND]
To Cancel: # 333 * BARRING CODE # [SEND]
To Check: * # 333 # [SEND]
All Incoming Calls
To Activate: * 353 * BARRING CODE # [SEND]
To Cancel: # 353 * BARRING CODE # [SEND]
To Check: * # 353 # [SEND]
All Outgoing Calls
To Activate: * 33 * BARRING CODE# [SEND]
To Cancel: # 33 * BARRING CODE # [SEND]
To Check: * # 33 # [SEND]
All Outgoing International Calls
To Activate: * 331 * BARRING CODE# [SEND]
To Cancel: # 331 * BARRING CODE # [SEND]
To Check: * # 331 # [SEND]
All Outgoing International Calls Except To Home Country
To Activate: * 332 * BARRING CODE# [SEND]
To Cancel: # 332 * BARRING CODE # [SEND]
To Check: * # 332 # [SEND]
All Incoming Calls
To Activate: * 35 * BARRING CODE # [SEND]
To Cancel: # 35 * BARRING CODE # [SEND]
To Check: * # 35 # [SEND]
All Incoming Calls When Outside Home Country
To Activate: * 351 * BARRING CODE # [SEND]
To Cancel: # 351 * BARRING CODE # [SEND]
To Check: * # 351 # [SEND]
Canceling All Call Barring # 330 * BARRING CODE # [SEND]
i hope it will help you...
Apr 13, 2011 • Cell Phones
4helpful
2answers
I have a nokia 2730c, my number is currently barred, do you know what the code for cancelling the barring? Thank You
hi,
All Outgoing Calls
All Incoming Calls
All Outgoing Calls
All Incoming Calls
1helpful
I want to knw hw i cn use my nokia 2700c security setting like wt is barring code and pin codes (and plz gives this two default codes )
PIN code is for simcard security the default is 12345...But if what you say is Locked code ,its the security of phone the default is 12345 ...about Barring code ,here is some tips...
All Outgoing Calls
All Incoming Calls
All Outgoing Calls
All Incoming Calls
I cant recieve calls on my nokia n95
Hi, since it is a nokia phone, and on the phone it has service signal bar showing on the screen of the phone, Just apply this codes #33#0000#( to cancel any beared calls(both in and out going calls and #002# ( to cancel any call divert on the phone.
NOTE: it will only work if the service signal bar on the phone the makes you know that there is service on your is full. If not, that means the phone network will be the problem which you will need to consult repairer.
Take care.
1helpful
Call forwarding
The 50 command is for call forwarding of an individual phone, not the incoming calls. There are several conditions that have to be met to make forwarding work. First, you need your ICD group extension. It's generally 600, but we use 100 or 199 or 200 sometimes. The command is in the back of the Operations Manual (OM) and it is in the form of (assuming 600) *71416009+number#. *7140600 cancels.
http://www.public.carl.airpost.net/TDA/200_TDA_OM_06-121.pdf
Here's a copy of the manual, just in case you don't have one. Page 192 shows the sequence. You might also look at *710 command on the same page for setting forwarding. It is quicker than the 50 commands and sets the status of your FWD/DND button.
Carl
1helpful
Try to cancel a function on my phone
If you are French it means: Appel reçu
If you are English it means: Call Received
To change your phone back to English, goto the set giving you issues
-> press the FEATURE button
-> dial * 5 0 1
This will change your telephone set back to the English language.
I want to cancel a function on my phone
I think it's not fare, yoy tell us your going to fix our problem for fre, and when we send our problem you eant to charge for it. My problem is not a big problem , it<s just someone that played with my phone, so I don't think I need to pay for that!
Have a great day, and I will try to fix it myself for free!
2answers
Tone And Message
Call Divert
The GSM standard knows two kinds of call divert:
  • Unconditional call divert
  • Conditional call divert
Conditional call divert occurs on any of three conditions:
  • Divert if no answer after 'x' seconds
  • Divert if unavailable (cellphone switched off or out of range)
  • Divert if line busy
Furthermore, the GSM standard knows three different types of call:
  • Voice call: normal communications when you pick up the phone to talk to someone.
  • Fax calls: the GSM terminal being called is a fax machine.
  • Data calls: your cellphone is acting as a modem hooked up to a computer accepting inbound data from elsewhere.
Each call type is assigned a number: 11 for voice calls, 13 for fax calls, 25 for data calls.
You can activate or cancel conditional call divert on your device. To do so:
##62# : Cancel divert for all call types
##62*11# : Cancel divert for voice calls
##62*13# : Cancel divert for fax calls
##62*25# : Cancel divert for data calls
This code does not hurt your device only helps it to tell it what to do in certain situation of a voice, data, or fax call.
This is a link to a site which goes a little more in depth with the meaning of conditional/unconditional call diverting is. Hope this helps!!!
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
