Sewing Machines Logo
Anonymous Posted on Jul 25, 2013
Hello dear My Janome 3160 QDC will sew fine, but if I want to do machine quilting just by straight stitching the bottom side thread occasionally will have a loop about1/16 of an inch in size in the stitch line. I take it back to the dealer and he tests it and returns it to me but when I get home it does the same loop, occasionally. This is unacceptable to me in my projects.
Debbi's Sewing Machine Repair
Level 3:
  • Janome Master 7,365 Answers
  • Posted on Jul 25, 2013
Janome Master
Level 3:
Answers
7365
Questions
Helped
1742768
Points
19451
Have you tried changing the needle?
have you tried adjusting the top thread tension?
it might be the needle and the thread are not compatable,, the needle may be to light for the thread.
if the suggestions don't help, sew on the sewing machine till it makes the loop and then stop the machine and take it to the repair man and let him see the loop and then ask him why it's making the loop.
Mister Danger
Level 3:
  • Janome Master 5,631 Answers
  • Posted on Aug 09, 2015
Mister Danger
Janome Master
Level 3:
Answers
5631
Questions
0
Helped
1198248
Points
47629
Some good videos are worth more then a 1000 words
Janome 3160 QDC 130038733 013
Janome 3160QDC
Janome 3160 QDC
Janome 3160 QDC YouTube
5 Related Answers
bargainbox
Hassy
  • 1388 Answers
  • Posted on Jul 24, 2008
SOURCE: My bottom thread is loose when sewing a straight stitch
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Anonymous
  • 323 Answers
  • Posted on Jun 27, 2008
SOURCE: Loose stitching underneath. HOW CAN I FIX!!!!
Sounds as though you may have a burr or rough spot on the hook where the bobbin inserts. Run your finger along the edge of the hook to see if there are any rough spots.I'm sure you're going to find at least one from the time you broke the needle.Once you locate it, remove it with an emery stick or small sharpening stone. Polish it so that it is smooth. Should work okay.
sewman7
SewTechWayne
SewTechWayne
  • 186 Answers
  • Posted on Jan 31, 2009
SOURCE: 5932 knotting every other inch
Try oiling the hook if you haven't recently.
Check you needle plate and hook for damage, they may need to be buffed or sanded smooth.
Check your upper tension discs for lint and double check your upper thread path (proper threading).
There are other things like hook timing, needle clearance or broken check spring that may be wrong but you need a technician for those things.
best of luck!
Mimito7
Kelley Buchanan
  • 130 Answers
  • Posted on Apr 19, 2009
SOURCE: Top thread stitches correctly but bottom thread loops.
FYI---- Loops on the bottom-- problem is in the threading..
Loops on the top--- problem is with the bobbin.
sew dutch
Ellen Den Dulk
  • 25 Answers
  • Posted on May 25, 2009
SOURCE: Juki HZL-E61: cannot get tension right on straight stitch
Loops on the bottom of the fabric direct the problem to the top thread. Rethread again and make sure the thread goes through the tension discs. Lift the foot, because this is what opens the discs. When sewing and the foot is down, the discs should be closed and thus giving the upper thread the tension it needs.
Janome 6500 Sewing Machine. CORRECT TENSION ON 6500 JANOME SEW MACHINE please.
Question edited for clarity.
Please don't type in all CAPS, it is considered SHOUTING and is harder to read.
Sewing machine tension is a delicate tug of war between the bottom Bobbin tension and the Upper tension to put the loop between the 2 layers of fabric. You set the Bobbin tension first and the the top tension depends on the fabric and the thread used.
Your Bobbin tension is very very loose to be not tensioning at all or the top tension is too loose.
Adjusting The Tension - Janome Memory Craft 6500 ...
ManualsLib https://www.manualslib.com > ... > Instruction book
Janome Memory Craft 6500 Professional Manual Online: balancing thread tension, Adjusting The Tension. Correct Tension: The Ideal Straight Stitch Has Threads ...
Best video on tension
LO comes up on my 3160 QDC Janome sewing machine.
Check for a thread jam under the needle plate. Wait for the machine to cool after the overload. Your material may be too thick or heavy for the machine.
I hope this helps.
The zig zag stitch on my Janome MC 3000 skips stitches all other stitches work fine. Any solutions?
Be sure stitch is in between the two fabrics when straight stitch. Adjust tension until stitch is between top and bottom fabric. Use different color top thread to make it easier to see. Once tension is correct sewing straight, switch to zigzag.
Remove hook race and bobbin. Clean area with vacuum.
Replace needle.
Try different thread and fabric.
Why is my stitch distorted
Top thread is "frayed"?
Could be tension is too high, problem with needle, needle wrong type, other.
Does it straight stitch ok using same fabric, thread, needle, bobbin, and tesnsion?
Janome 3160 qdc drop feed dogs
Look on the back side for a slide type switch.
2helpful
I have a janome 1600P, it will not sew without either the top thread breaking or the bobin thread breaking. It will sew for about a quarter of an inch and then the thread breaks, I have changed the bo
My experiences with thread breaking with machine on a quilting frame make me look at the upper tension being set too high, the needle being worn or movement of the machine is too fast. Reduce the upper tension first, then sew in straight lines at first. See if you can sew slowly, in straight lines and reduce the upper tension until the thread stops breaking. If so, try some 1-2 inch circles, again going slowly. If the needle thread is pulling to the back, you will need to increase the upper tension again until the stitches meet in the middle of the fabric. If you can't locate a balanced spot where the needle thread is not pulling to the back side and thread doesn't break, try taking the machine off of the frame and sewing on a table. If it won't sew this way, it needs some professional help. If it does, you will probably save a lot of time taking it in for service, making sure to explain to the repair center that you have problems on a quilting frame, not while sewing normally. When the machine is adjusted to sew normally on a table and you move it to the frame, you will probably need to reduce the tension by 1-2 complete turns of the tension knob.
I have a Janome Mycompact which is about 20 years old. When stitching, the thread from the bobbin is a straight line and the thread from the needle is perfect. How do I adjust or fix the way the bobbin...
Unthread the machine. Set the upper thread tension to 5 and raise the presser foot. Rethread the machine. With the presser foot up, pull about 12" of the upper thread through the needle and make note of how much tension you feel. Lower the presser foot and you should feel the thread get very tight. Also, make sure that you are using good sewing machine thread and not hand quilting thread, upholstery thread or too heavy weight thread for the machine.
Janome 2030 QDC How to predict whether the buttonhole (24) will start forward or backward? I power off the machine and reselect stitch 24 and move the buttonhole presser foot to the start position every...
does it sew buttonholes both ways?
My Janome 6500 always buttonholes away from me, so when it starts, it sews the near bartack, then stitches backwards down the right hand side of the buttonhole. It then comes back with little straight stiches on other side and sews the zigzag backwards on the left side, then the far bar tack. I would have thought your Janome would do the same stitch sequence.
Janome 1600P quilting free motion sewes fine for a bit then top thread starts looping on the back. It is not consistant
Please ensure that you are uing the correct size needle for your that you are using. are you using a straight stitch needle plate. Please let me know what size thread and needle you are using
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
