2004 Saab 9-3 Logo
Posted on Mar 31, 2009
On my saab vector ignition key functions
I have a function on the fob symbol just a white line when pressed the side lights come on and te=he wing indicaters come on permantley ie not flashing any idea
Anonymous
Level 1:
Problem Solver:
  • Contributor 1 Answer
  • Posted on Apr 01, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
1152
Points
I have a Saab 93 Vector and although my key does not have that function my manual says the following; 'Press once - Turns on exterior and cabin lighting, for 30 sec, or turns off lighting. Deactivates panic alarm. Hold and press for more than 2 sec - Cars with car alarm: panic alarm (activates alarm manually).
There is another section that says the button turns off lights and larm when activated and the car remains locked. The panic alarm can only be activated when the car is stationary and it will be silenced when the car is driven away.
Hope that makes sense. Enjoy your Saab 93 - I know I do every day.
Tony
2answers
How to program fob for 2011 chevy malibu
google how to program fob for 2011 chevy malibu for more info
On the Chevy key fob, press and hold the "Unlock" and "Lock" buttons at the same time until you hear the door lock and unlock again. This means you're all set. Re-insert the programmed key back into the ignition to the "On" position to finish the Chevy key fob programming process
2helpful
2answers
09 Pontiac G6, My car shows the yellow car and lock symbol, but the security system works just fine.
The yellow car and lock symbol that appears on the dashboard of your Pontiac G6 indicates that the vehicle's security system has detected a problem. This symbol may appear if there is a malfunction with the system or if the system has been triggered by an event such as a collision or attempted break-in.
If the security system is functioning properly and the yellow car and lock symbol is still displayed, it is possible that there is a problem with the security system sensor or wiring. It is recommended to take the vehicle to a mechanic or a Pontiac dealership for further diagnosis and repair.
In the meantime, you can try pressing the unlock button on the remote or using the key to unlock the doors and see if the symbol disappears. If the symbol remains displayed, it is possible that the security system will need to be reset by a professional.
Wing mirrors and central locking stopped working on Kia Picanto Halo 2012
Quit SHOUTING will ya :>D Typing in all CAPS is considered SHOUTING in Internet land. It also make the text VERY HARD TO READ.
You need a good, local auto electrician with a pro-grade scan tool computer. You have a faulty module probably Body Control Module, or Security System Module, the sensors and receivers connected to them, or a general communication issue.
2008 mercedes benz e 350 key fob unlocks doors and open trunk but will not lock doors ansd no blinlking light on key fob
Have you tried both fobs? sounds to me like the button itself on the fob above the MBZ symbol for locking isn't working. You can take the key fob apart, and check the little buttons on the PCB / board itself for function. Sometimes they get stuck with dirt / grime to the point where the button itself under the plastic shell is not engaging.
My immobilizer does not recognise my key fob
Put key in ignition.
Press unlock button on key fob.
Immobilizer should now recognize it, if it was original fob but car or fob battery was changed or is now low.
Saabs are particular about batteries that are otherwise good, but just below 12 volts.
My hyundai i10 wont lock or unlock when using the press button on the key
Hyundai Grand i 10 Central lock module resetting process (2014 Model) Step 1 Enter car and close all doors. Step 2 Kept Fob key in hand Step 3 Repeat the below process 5 times 1 Turn on the Acc mode, Press the Fob key lock button 5 times and turn off the Ignition switch 2 Turn on the Acc mode, Press the Fob key lock button 5 times and turn off the Ignition switch 3 Turn on the Acc mode, Press the Fob key lock button 5 times and turn off the Ignition switch 4 Turn on the Acc mode, Press the Fob key lock button 5 times and turn off the Ignition switch 5 Turn on the Acc mode, Press the Fob key lock button 5 times and turn off the Ignition switch End After head a small beep from central lock module stop the process ( Beep sound is the Success Signal)
I have a Saab 93 TID (2005 Vector) KEYFOB PROBLEM!
I suspect you have a problem in the security system receiver module, which in most cars must be programmed by the dealer.
2helpful
3answers
2001 saab 9-5 electric door lock system does not function
Most likely you have a bad TWICE unit. it is located under the driver's seat, at a low point in the floor and often gets wet.
Top Saab Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Saab Expert? Answer questions, earn points and help others
