Konica Minolta bizhub 350 All-In-One Laser Printer Logo
Posted on Mar 31, 2009
BIZHUB 350 THROWING CODES C1183 AND NOW SHOWS C5351
Just bought this Bizhub 350 off lease and throwing codes C1183 at startup and now it shows C5351...Is this a result of the copier movers jarring something during delivery or? Any thoughts welcome and thanks in advance
  • brendaglegho Sep 18, 2009
    I don't have the manual to see c1183 finishing option elevator drive malfunction. I need to solve this problem could you please tell me how to do this.
    Thank you
    BGG
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 31, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2729
Points
6
Yes, that is it..... The company I purchased the unit from sent a company they use for service out to my house (free of charge)and the finisher needed to be aligned because it was off from the movers who delivered it...It is a fantastic unit...very happy with it.
  • Mike Matkovic Dec 06, 2014
    Hi, I have the exact same problem !! What did they exactly align ? How ? Thanks so much !!
Anonymous
Level 1:
  • Contributor 24 Answers
  • Posted on Jun 25, 2009
Anonymous
Contributor
Level 1:
Answers
24
Questions
Helped
74134
Points
39
C1183 Finishing option elevator drive
malfunction
See FS-514 Service Manual.
See P.65
Anonymous
Level 1:
  • Contributor 4 Answers
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3129
Points
Many times at lease end, the wholesaler refurbishes the unit as it must be up to spec for an authorized servicing company to provide service. Sounds like something was refurbished with a different compatible part.
I would like a list of error codes for the Konica Minolta bizhub 350
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Konica-Minolta&model=bizhub%20C350
Me sale el codigo C5351 en la Konica Minolta bizhub 350
power supply cooling fan motor M-4
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Error code c-0204
remove draw #2 remove the paper behind it. also do not store paper on the left side of the draw. its not a storage area its for 11 x 17 paper.
It shows 5351error code
Hi kjmichael,
Other than trying to reset the code by opening/closing front door or switching it on/off it'll probably need a technician to look at it. The C5351 code refers to the power supply cooling fan motor not working correctly.
Good luck
Regards
m-press.biz
C-5354
Cooling Fan Motor Failure. Can't tell you which one tho as the factory service manual shows C5351, C5352 and C5353 but does not list a service code C5354. If by chance it is one of the other codes then let me know and I can tell you which it is. Minolta's throw cooling fan codes sometimes. You can usually reset the code will "bumping" the machine and they will at least run ok until the motor stops in the "dead spot" again.
Good Luck and Thank You for using Fixya.
1helpful
2answers
BIZHUB 350 C1183 MALFUNCTION
Hi richard_hutc,
It would appear that you have an issue with the finisher/sorter on the side of the machine.
Specifically, C-1183 means the elevator motor hasn't ascended or descended correctly.
Open and close the finisher and look for any paper jams in this area.
Good luck
4helpful
2answers
Bizhub 350 erro code c1183
C1183
Elevator motor ascent/
descent drive failure
• The elevator tray lower limit sensor (PC13) is not turned ON
even after the set period of time has elapsed after the main
power switch is set to ON.
• The elevator tray home position sensor (PC11) and elevator
top face detection sensor (PC12) are not turned ON even
after the set period of time has elapsed after the elevator
motor (M11) is energized.
• The elevator tray does not stop at the position for the specified
tray after the elevator motor (M11) is energized (beginning of
descent operation) and the elevator tray lower limit sensor
(PC13) is turned ON.
• The elevator top face detection sensor (PC12) is not turned
ON even after the set period of time has elapsed after the elevator
motor (M11) is energized (beginning of ascent operation)
when paper is being fed out.
3helpful
Konica Bizhub Password Reset
Konica Bizhub c350 default password is 12345678 give that a try
3helpful
Bizhub 200 fault code c1183
Its an elevator ascent/descent motor failure. You didnt by any chance have any thing such as a big box of paper or a trash can sitting under the exit trays did you? Check it to make sure the trays are level also.
1helpful
4answers
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
