I've threaded it and rethreaded it about thirteen times, made sure all the tensions were right. I'm using one needle, not two, as I have on every serger I've ever used. The three lines WILL NOT, under any circumstances, interlock to create the serged edge. I got it to serge for about two seconds before one of the threads somehow magically dislodged itself from the needle's hole (without breaking), and now all it does is feed the threads separately through the machine/fabric.I just purchased this machine two months ago, and I've used it MAYBE four times.
SOURCE: Babylock Eclipse SX won't catch the overlock stitch
SOURCE: Baby Lock Serger Thread keeps breaking
Mmmm...., maybe NOT the solution, maybe, just a key.
I have a copy of theBaby LKock EA-605 instruction booklet in English, Germann, French and Spanish. NO ideas how it casme into my orbit, but happy to pass it on.
SOURCE: kenmore serger thread keeps breaking
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
