Canon Rebel XT / EOS 350D Digital Camera Logo
Posted on Mar 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon 450D, ERROR 99 only when flash pops up
Canon EOS digital rebel XSi / 450D. Canon 18-55 lens.
Accidently had my finger holding down the built in flash when it was popping up. Then when I tried to take picture on auto, the flash pops up fine but screen shows "busy" then err 99. on and off, changed battery. Still won’t work properly.
Camera takes non-flash pictures fine.
Help!
  • Anonymous Mar 20, 2014
    My canon eos 1100d flash is not working.its show err 05 cannot raise the built in camera on the screen
Anonymous
Level 2:
Novelist:
  • Expert 155 Answers
  • Posted on Apr 09, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
155
Questions
Helped
84794
Points
355
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 1 Answer
  • Posted on Jun 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
4424
Points
My canon 450 xsi is not coming on after the error 99 message what should i do now i have tried what wa sent to me but nothing is happening
What is the latest firmware for canon 450d?
1.1.0 and this site from Canon, you can download the firmware.
Canon EOS REBEL XSi 450D Firmware Download
Only when you have a new lens, not yet supported by your came, I would get the firmware.
Canon rebel xsi error 99
Yes - internal damage caused when it struck the table.
Canon Rebel EOS Rebel Ti1 will not auto focus
The lens needs servicing, because the lens is stiff the auto focus motor cannot turn the lens to focus.
How do u turen auto flash off on CNnon EOS Rebel XSI 450D camera?
Is it normal to adjust the sharpness when downloading my pics. to picassa from my rebel xsi
1helpful
CANON EOS REBEL XSI 450D BODY WHEN TAKING A PICTURE ERROR 99 COMES UP
Unfortunately, the Error 99 code is a catch-all code that means an UNKNOWN error has occurred. Because of this, it is difficult to pin down exactly what is causing the problem.
It could be a fault with either the camera (main circuit board, software, shutter mechanism etc.) or even the lens.
For starters, I would make sure that the lens electrical contacts are clean and the lens is mounted correctly and fully locked home. If you have a spare lens, try that also.
Next, I would reformat the memory card (do this in camera). If you have a spare memory card, try that also.
Check that the battery contacts are clean, and also the contacts of any external hardware such as vertical grips.
If none of these solve the problem, the only option left is to take it to a Canon service agent :-(
Hope this helps,
Matt
Canon 450D - Error 99 only when flash pops up
Flash Tube is bad inside the Flah head, tccamerarepair.com
9helpful
2answers
CANON eos 450D error 05
I have had the same problem with my 450D. I have been living without flash on my cam for a month. Until I realized that maybe something liquid and sticky by chance got where the flash is...so i just trid to hold uo the flash my insrting my nail into the small space between the flash and the camera and tried to press the flash button. IT WORKED!!!
2answers
I know what you two are talking about. I ordered a Canon EOS 300d from a site called "Keh" and I had never used one before... so I get it in the mail on time. The camera works fine for a few minutes then I get an "error 99" and can't do jack with the camera. I researched online and even called keh ... I read and heard that it has to do with the lens... so I sen't the camera back and got my money.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
