It's either the blower motor switch or blower motor resister. Resistor ?Heater Blower Motor Switch Removal Remove the battery (10655) ; refer to Section 414-01 . Remove the battery tray. Remove the screws. Remove the battery tray. Disconnect the heater blower motor switch resistor connector. Remove the heater blower motor switch resistor (18591). Remove the two screws. Remove the heater blower motor switch resistor. ----------------------------------- Switches Removal Disconnect the battery ground cable. Remove the center trim panel; refer to Section 501-12 . Remove the control assembly. Remove the screws. Remove the control assembly. Remove the A/C-heater function selector switch knob. Disconnect the vacuum harness connector. Disconnect the A/C-heater function selector switch connector. Remove the A/C-heater function selector switch. Remove the screw. Remove the A/C-heater function selector switch. Remove the temperature control switch knob. Disconnect the temperature control switch connector. Remove the temperature control switch. Remove the screw. Remove the temperature control switch. Remove the heater blower motor switch knob. Disconnect the heater blower motor switch connector. Remove the heater blower motor switch (18578). Remove the screw. Remove the heater blower motor switch. ----------------------------
SOURCE: 98 Dodge Intrepid Blower stuck on high and no display.
Yes you car has something like a resistor but its called an ATC BLOWER CONTROL MODULE.Its under the dash on the pass side close to the firewall.
SOURCE: my 1998 astro van blower motor only works on high speed.
No the motor is not bad or going bad, the heater blower motor resister is bad, thats regulates the blower speeds, its located under dash by heater motor 2 screws hold in heater box with a electrical plug to it.
SOURCE: 1996 plymouth voyager van blower --high only
YOUR BLOWER MOTOR RESISTOR IS BAD OR THE BLOWER MOTOR CONTROL SWITCH COULD BE FAULTY.
SOURCE: We have had an on going problem with the heat in
you need to replace the blower motor resistor,that is what give the motor its different speeds,
SOURCE: Location of a/c blower high speed fan relay 2001
hi...
please check the under side of the steering wheel most probably all relays wil be placed there. check and please let me know about it.
