Question about HP Pavilion A250n (DF253A#ABA) PC Desktop
My HP a250n boots up to the windows logo, then the screen goes black and stays that way. Hdd continues to spin.
    Scholar:
  • 150 Answers
Sounds like your windows installation was corrupted. Try booting into safe mode from BIOS. If that doesn't work you will need to re-install Windows.
Please rate, Thanks!
Posted on Mar 31, 2009
SOURCE:
Computer goes black and jumps between hp logo and black screen.
Knowing Hp it is either hdd errors, (damaged files, should boot from a DVD) or a problem with the GPU.
May 05, 2016 | HP Computers & Internet
System not booting normally
Its going to safe mode every time...actually Safe Mode is for to change any setting or get backup and some more... better to change the OS.. everything will be perfect after taking data backup... i think it will help u....
Apr 03, 2014 | HP ProBook 4510s FM849UT Notebook
Acer is going straight to a black screen after the acer logo in startup....it just shows a tiny blinking line. It goes no farther. I need help fast
Apparently your Acer cannot find the operating system. As soon as the Acer logo comes up, there should appear in one of the bottom corners "F" & a number should appear. Immediately start pressing that F number (top row of keyboard). This should take you to a boot screen. Scroll down to boot sequence. Hit enter. Make sure boot-up sequence is CD or floppy drive first, second should be HDD, then escape. Restart computer. Should then boot off CD drive. I am assuming you have an operating system (XP, windows, etc.). Let me know if this doesn't work.
Apr 07, 2013 | Acer Aspire 5734Z4386 Notebook
Black screen, Blinking cursor for 25-30 seconds after HP logo at cold boot.Restarting PC does not add this extra step before windows startup screen. Booting from power off condition has this condition...
AS YOU ON THE SYSTEM AND EVEN BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
May 02, 2011 | HEWLETT-PACKARD Hewlett Packard HP ENVY...
Lap boots up, shows dell logo then screen goes black but runs.
ur unit is overheating turn off and unplug and let cool down,clean vents around fan intake (under unit) and around top each side of keyboard when cool enough plug back in and listen for fan operation while booting up if no fan it may be stuck or burnt up and may need replacement but ur biggest problem will be the hard drive if it was overheated for to long could or is damaged good luck hope ur lucky and that it just got hot
Dec 05, 2009 | Dell Inspiron B130 Notebook
Boot failure self HDD test #1-7 XP PRO.
Hi this Alex You can use Ntfs for dos programm which allow you to access ntfs partions on while dos loaded. then you will be able to get you data copied
Sep 23, 2009 | HP Pavilion dv4000 Notebook
Black screen on Acer 4720Z
If your booting to the splash screen ( ACER Logo screen ) then it goes black reboot - access the bios and do a bios hdd test - you mostlily find your hdd has died. Head scrash
Mar 07, 2009 | Acer Aspire 3690-2196 Notebook
Compaq Presario C304NR STOPS LOADING AT COMPAQ LOGO
It sounds like the hdd has failed. When you try to boot can you hear the hdd attempting to spin up? Best solution if everything else checked out would be to replace the hdd. Hope this helps & please remember to rate my answer. Thanks.
Dec 31, 2008 | HP Compaq Presario v3000z Notebook
Inspiron B130 won't boot
plz try to boot through safe mode, if you can then log in normally.
if you cant boot from safe mode then you have to reload or repair your os.
Dec 23, 2008 | Dell Inspiron B130 Notebook
Open Questions:
Hp Printer@^+[1]=855-221-4867@&@tech Support Phone Number Hp Printer Tech Support Number Hp Printer@^+[1]=855-221-4867@&@tech Support Phone Number Hp Wireless Printer Tech Support Number HP Printer Tech Support Number+1(855) 221-4867 time to gayo independently owned and operated all kind of technical support. There are a long series of HP Printer s including latest technology and affordable price. HP Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus s are compact and lightweight.HP Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of technical support. There are a long series of HP Printer s including latest technology and affordable price. HP Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus sare compact and lightweight.HP Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of technical support. There are a long series of HP Printer s including latest technology and affordable price. HP Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus s are compact and lightweight. HP Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of HP Printer s including latest technology and affordable price. HP Printer produce All-In-One with basic printinG copying and HP Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of HP Printer s including latest technology and affordable price. HP Printer produce All-In-One with basic printinG copying and scanning functions. s are compact and lightweight.HP Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of HP Printer s including latest technology and affordable price. HP Printer produce All-In-One with basic printinG copying and scanning functions. s are compact and lightweight.anning functions. s are compact and lightweight hp printer black not printing hp printer drivers hp printer drivers download hp printer drivers for mac hp printer drivers for windows 7 hp printer drivers for windows 8 hp printer drivers for windows xp hp printer error hp printer error 49.4c02 hp printer error 79 hp printer goes offline hp printer goes to sleep hp printer goes to sleep mode hp printer going offline windows 8 hp printer job won't cancel hp printer keeps going offline hp printer keeps going offline windows 7 hp printer keeps going to sleep hp printer keeps losing connection hp printer keeps losing wireless connection hp printer keeps pausing hp printer keeps printing blank pages hp printer keeps printing test page hp printer keeps saying offline hp printer loses wireless connection hp printer not connecting hp printer not connecting to computer hp printer not connecting to mac hp printer not printing hp printer not printing black hp printer not responding hp printer not scanning hp printer queue will not delete hp printer quit printing hp printer tech support hp printer tech support number hp printer troubleshooting hp printer troubleshooting mac hp printer very slow hp printer wireless setup
Jul 23, 2019 | HP Computers & Internet
See all HP Pavilion A250n (DF253A#ABA) PC Desktop Questions
HP Pavilion A250n (DF253A#ABA) PC Desktop Logo
243 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
