Garden Logo
Posted on Mar 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the spec for magneto clearence on a mcculloch fr4618
DROPNDEAL
Level 3:
Top Expert:
  • McCulloch Master 2,931 Answers
  • Posted on Mar 10, 2018
DROPNDEAL
McCulloch Master
Level 3:
Top Expert:
Answers
2931
Questions
0
Helped
932732
Points
21770
Refer to your service manual.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
i need the spec for magneto clearence on a - helpful-rx44h4hsqebyqg3voy0wii3n-2-0_5.png
1 Related Answer
philwalker78
Phil Walker
  • 610 Answers
  • Posted on Aug 30, 2012
SOURCE: install coil on homelite ut10518
Hi Hiram, 8 thou is the correct gap. Regards Phil.
Testimonial: "Thank you very much"
1helpful
My McCulloch 338 will not start, but does have spark are there points under flywheel
No there are no points. It has an "ignition module" which is a fancy name for a magneto with integrated electronics that eliminates the need for points.
You have "spark" so likely its a fuel (carburetor) issue or has developed a crankcase leak.
If you suspect spark is not at proper time, that would be a stripped flywheel key.
1helpful
My McCulloch 338 chain saw will not start has spark though, does it have points behind flywheel
There are no points. It uses an integrated electronic controlled magneto.
How do I sand the magneto on a Briggs & Straton 19.5 engine?
No need to sand it..it works on magnets rust does not effect it..but if you wish too.Remove the top cover of the engine and remove the mag..just make sure you measure the clearence with a clearence gauge before removing most are about the thickness of a business card...good luck
Magnetizing a mcculloch slick magneto
As fascinating as that sounds, I really have no Earthly idea.
I recommend contacting your local authorized service center for assistance.
Contact us
User manuals McCulloch Service
I trust this information proves beneficial.
Mcculloch parts manual
you can purchase the magneto at most any parts shop unless its an obsolete saw. the magneto is located on crank cooling fins under the pull start
Jan 07, 2014 • Garden
1helpful
Not getting spark to plug on eagerbeaver 2014
Jeffuxum:
The magneto is probably where the problem is. You'll need to pull the cover off of the motor and check the gap between the magneto and the flywheel. If the bolts holding the magneto have vibrated loose, the gap between the magneto and the flywheel will be incorrect. While you have the motor cover off, check the wiring to make sure you don't have a short in your ignition wiring and clean the air filter. I don't remember what the gap is between the flywheel and magneto, but .010 In. sounds familiar. Both legs of the magneto should be the same distance from the flywheel and they must not touch the flywheel at any point. I have used a matchbook cover between the flywheel and magneto while I tightened the magneto retention screws and it worked.
1helpful
Install coil on homelite ut10518
How you put the prim bulb on a fr4618 chine saw
If you buy the new one first.You will see that they just snap in and out.It will say on the back of the bulb carb and tank in very small letters.Reinstall the fuel lines just as it says.You need to unbolt the pull rope side cover to get to it.Don't worry nothing will fly out at you.
Top McCulloch Garden Experts
Jay Finke
Jay Finke
Floyd Rogers
Floyd Rogers
Level 1 Expert
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
