It just wont see the headset
1. Charge it 4-7hrs 2. When ready, it must be light up either Green or Red when you PRESS IN on the Up/Dn Volume button 3. Press and hold the Answer button (on microphone boom) for 2-3secs, then Push IN and UP on the Up/Down Vol button'Light should flash Red/Green/Red/Green..... 4. Go to Phone, Enable Bluetoth and tell it to FIND new adapter/Devices 5. When it 'finds' M2500, punch in 4-zeroes (0000) and hit enter/Dial and it should connect 6. When connected, the 2500 will flash BLUE Thats it! If it will not charge up (light either RED or Green) the charger is bad, or the M2500 Battery is gone. I opened mine up and will (!) replace its pack eventually, but it is consisted of 2 tiny batteries, about 1/4 as long and same diameter as a AAA connected together. They measure 1.3v each, but I think this is SUPPOSED to measure 2.4v/4.8v(?) To Open, you have to use force and pry it apart starting at the charger socket end. Go slow and it wont break.
Did you set your headset to pairing-mode before you searched for it ? Must headsets dont broadcast their prescence by default.
