SanDisk Sansa Clip MP3 Player Logo
Posted on Mar 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sansa clip 2mg fm radio not putting out sound
Radio has worked fine up to now. No changes made, nothing dropped, etc. but now radio has quit putting out sound. Stations still show, have redone auto station, got same ones, but when tried, no sound from earphones. Get music playing fine from loaded mp3 files, so not earphones. Not sure what I can do next.
ThaMp3Doctor
Level 3:
  • Master 8,597 Answers
  • Posted on Mar 31, 2009
ThaMp3Doctor
Master
Level 3:
Answers
8597
Questions
Helped
2174840
Points
14133
Go into the Settings menu of the Sansa, and change the region to "World" if you live outside the US, and change to "United States" if you live inside the US. Then, go back to the Radio mode and see if there is an icon that looks like a block (technically, a "Stop" sign) - if there is, press up on the clickwheel - it will get your radio off of pause mode. You radio should now work again.
1helpful
2answers
I need help disabling my fm radio on my new sansa clip.
This is possible. It requires firmware upgrade to disable the FM radio. Follow the directions below link:
http://kb.sandisk.com/app/answers/detail/a_id/5224/~/removing-the-fm-radio-feature-from-the-sansa-clip%2Fclip%2B%2Ffuze-player
Good luck.
18helpful
2answers
FM radio on Sansa Clip does not work
Have you muted the radio by mistake.If you have there will be a square symbol under the FM sign.Press the top of the ring.
2helpful
2answers
No sound from radio on sansa clip. mp3 playing still works fine.
Did you accidently pause radio. put sansa in radio mode and push the play/pause button.
4helpful
My sansa clip won't play the songs I loaded on!
I've had this happen a couple of times in the last 6 months. You can get it to play again by chosing the format option from the settings menu. Of course, then you've lost everything you had loaded on to it. Download your music/audio books again and they will play.
2helpful
Radio won't play
1) Go into the settings menu, go to FM settings, and make sure the FM Region is set for United States. If you are outside the US, change it to "World"
2) The radio might initially be set for Pause - to test this, turn to a specific radio station that you know you get, and press up on the clickwheel. The "block" icon underneath the radio station should now change to a play arrow, if indeed it was on pause.
I have a sansa clip mp3 but i can't turn on the fm radio. help
No sound for FM radio mode
The radio is weak on this device - try different areas of the house, and see if you can get reception on one good station. I have heard that the Sansa e200 series had the radio function ruined by a firmware upgrade, but it wouldn't apply to the Sansa Clip. As a last resort, you can reset all of your settings within the player itself- the user manual will show you how to do this.
-Tha Mp3 Doctor
Sansa clip - not able to playlist listen on car radio w/ adapter
Can I get FM Radio
Press the home button to access the various menus, including fm radio
Here is a link to your user's manual :
http://www.sandisk.com/sansa/assets/English/products/Clip/Clip_userguide_en.pdf
-Tha Mp3 Doctor
No radio in menu. only music. voice .settings .
The service may not be available in your area. Make sure the headphones are connected to the player when searching for radio stations: Here's pg 15 of the user manual:
FM Radio (if applicable)
The Sansa
player includes an integrated FM radio for listening to live broadcast FM
stations. Please note that the FM Radio function may not be available in your region.
Listening to FM Radio
To listen to live broadcast FM station, follow these steps:
1. Select FM Radio from the Main Menu.
2. A radio frequency menu will appear.
3. Press |<< or >>| to adjust and search for the desired frequency, or select
preset by pressing Select.
4. For fast search, press and hold the |<< or >>| buttons.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
