How do you get rid of a 60.02 error on a HP Laserjet CP3525?
2 Suggested Answers
SOURCE:
shishirgarde
  • 114 Answers
SOURCE: HP Color LaserJet CP3525 68.X PERMANENT STORAGE
Perhaps this link may help you !
http://h200003.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=de&cc=de&taskId=125&prodSeriesId=74301&prodTypeId=18972&prodSeriesId=74301&objectID=bpl11648
Posted on Nov 01, 2009
Why does hp laserjet CP3525 says A4 in tray 2?
Based on my experience, it is likley that the document you are trying to print was originally formatted for A4 and hence when you go to print it asks for that paper. I have also run into a few fresh driver installs that default to A4(european) paper sizes.
May 23, 2014 | HP Color LaserJet CP3525x CC471AABA...
When i sand a test page the printer show an error 59.f0 what can i do
Pull the transfer unit out, and turn the white gear on the side. Not the one that turns the transfer belt--the one that causes the belt to push up against the toner cartridges. If the gear turns somewhat freely (it's not stuck), then reseat the transfer unit and see if the error goes away.
More comprehensive troubleshooting guide is here:
http://www.partsondemand.co.nz/uploads/97806/files/Feb_14_59.F0_error_Tech_Talk.pdf
But if it passes all the "checks" and you still have the error, check this out:
http://cincinnatiprinterrepair.com/hp-cp3525-59-f0
Apr 22, 2014 | HP CP3525N Color LaserJet Printer
Hp cp3525 service password
Pin Code for 3525is 11420002. You use the up and down arrows to display each number and the check to select it.
Feb 05, 2014 | HP CP3525N Color LaserJet Printer
Hp color laserjet cp3525
CP3525-59.FO ERROR. 1. TRANSFER BELT FLAG/ACTUATOR, WORKING? 2. SENSOR CHECK BEHIND CYAN TONER CARTRIDGE, WORKING? THESE 2 ARE IN THE BOOK AND EASY TOO CHECK. 3. MY ISSUES WAS THAT I REPLACED THE FUSER PRESSURE RELEASE MOTOR ASSY, BUT DIDN'T REALIZE GEARS WERE MISSING FROM SECOND HAND UNIT COMPANY ORDERED.:(. GOT MACHINE WORKING, BUT CYAN CAM IS OUT OF ALIGNMENT AND HAVE TO REINSTALL MAIN DRIVE AND CALIBRATE.. THIS ALL STARTING BY NOT USING HP SUPPLIES. BAD TONER CARTRIDGES HAVE TURN THIS JOB REAL UGLEY!!
Apr 17, 2013 | HP LaserJet Office Equipment & Supplies
Hp 3525 toner collection unit
Hi
you are looking for toner bottle, no need to replace a new one.
just clean well and replace that works in full.
first use a vacuum, something that used to Place inside the collector to be able to aspire then use tissue paper and clean.
Mar 11, 2013 | HP toner collection unit for laserjet...
I need to iverride the lock menu and I do not have the password.
The PIN for the HP Color LaserJet CP3525 Series is 09352508
Jul 07, 2011 | HP CP3525DN Color LaserJet Printer
HP CP3525 loud grinding noise when calibrating after printing
Sounds like you have a stripped gear somewhere. Probably somewhere in the paper drive assembly. Take it to your nearest printer repair shop, because tech support may not be much help with that.
May 20, 2011 | HP CP3525N Color LaserJet Printer
Marca error 60,02
60.2
The tray 2 lifter-motor is not functioning.
1 Turn the printer off and then on.
2 If the error persists, turn the printer off.
3 Verify that the tray 2 lifter wire-harness
is full seated in its connector on the
dc controller PCA (location J93).
4 Replace the tray 2 lifter-driver
assembly. See Tray 2 lifter-drive
assembly.
5 Replace the dc controller PCA. See
Dc controller PCA.
Aug 09, 2010 | HP LaserJet 4250dtn Printer
HP Color LaserJet CP3525 68.X PERMANENT STORAGE WRITE FAIL
Nov 01, 2009 | HP Color LaserJet CP3525x CC471AABA...
Open Questions:
839 people viewed this question
k24674
Marvin
Marvin
