I downloaded the 91iHome app from appslib. a few days later i couldnt get passed the "android" part of the startup screen. when i plugged it up to my charger, the pop-up for "foreclose" came and when i pressed it, it came back!!! my screen is so un-calibrated and when i try to press the 2 buttons for mount or charge only its really hard. my sd card is only 1gb and wont fit into anything. PLEASE HELP SOON!!!!!!!!!!!!!!!!!!
SOURCE: blank screen on boot
hi firend
u havre to do this chk the ram remove & clean it reinstall it in your pc if problem occers then
u have heting problem ur prosser fan has been dust so remove your prosser fan clan it put it back agin
SOURCE: Cannot access Appslib app library
I couldn't either! So, I uninstalled the appslib and reinstalled it and it works great now! You have to reset everything and you will lose apps I guess if you have any, I had none so this didn't affect me. If you go to Coby's website and under FAQ's it explains how to uninstall and install. Good luck!
SOURCE: How do i copy .apk apps from my computer to my
Just use the provided USB cable and connect the tablet to PC. Windows will recognize it as another drive (USB Mass Storage similar as USB HDDs and USB sticks). Copy the APK file anywhere (for example to Downloads folder. Then unplug from PC and run the Files application on Archos. Browse to the directory and clicking on the APK filewill start installation process.
Testimonial: "Thanks, was easy to figure out compared to my friends Kyros. Even got that GAppsInstaller .apk installed..."
SOURCE: i have an archos 28
From the Archos User's Manual.
- Press and hold the
power button until the ARCHOS banner is displayed and then release it.
- Press the power
button twice (like a mouse double-click) while the banner is still
displaying.
- A white Recovery
screen should appear within a couple of seconds.
- To move from one
option to another, press the power button. To select the highlighted
item, hold down on the power
button.
You'll want to select the Format System option.
