Computers & Internet Logo
Robert Watson Posted on Jul 22, 2013
Kenmore elite stove flashing f11 - Adaptec Computers & Internet
5 Related Answers
Anonymous
  • 213 Answers
  • Posted on Nov 22, 2007
SOURCE: kenmore elite gas stove
f-1 means the ERC is bad. sometimes turning the breaker off for a couple of min will help but if not the the clock/oven control needs to be replaced
Anonymous
  • 261 Answers
  • Posted on Sep 13, 2008
SOURCE: Kenmore Elite H3 error code F11
F11 is a serial communication error. It is recomended to check connections from the motor control unit to the ccu. We are looking for the blue wires that carry info from component to component. The ccu is on top under the cover positioned in back for older machines and front right for new machines. The mcu, motor control unit is behind the kick panel below the door and is front left usually.Again we want to unplug check for dark or crusty connections if not to carefully reseat the connection and not only the blue serial wires but power as well. Remember to first unplug the machine and while you work the machine can reset, 30 minutes is typical.
Anonymous
  • Posted on Oct 17, 2008
SOURCE: kenmore elite he 4t washer
I have the he4t and everytime I wash I get an f02 error. The washer wont drain and spin unless you cancel and restart the washer. What can I do to fix this?
Anonymous
  • 3741 Answers
  • Posted on May 05, 2009
SOURCE: Washer stops with F11 code; door won't open
F-11 ERROR CODE MEANS :
Serial Communication Error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
TO RESOLVE THE PROBLEM:
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Anonymous
  • Posted on May 28, 2009
SOURCE: my kenmore elite electric slide in range displayed error and F13 and the oven won't turn on
i phoned Sears about error code f13 on a gas range, and was told to unplug the range for 30 minutes. i think she meant 30 seconds - to reprogram the microchip. i unplugged it for 15 minutes or so, then reconnected, and it worked.
Kenmore elite electric stove. model 79099013102. Intermittent starts beeping then flashing "F7".
The "F7" fault code could mean a stuck or shorted key pad/console or it could mean a failed oven control board. There is no way to reset the control.
A service technician would determine if the problem is with Key Panel/Console or the Oven Control by: See image below.
NOTE
: This is intended for the service technician. I do not recommend attempting to diagnose which one has failed. This test must be performed while connected to the power supply.
I recommend calling a service technician to diagnose and repair your range
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
if its a Kenmore model then this message says that the button control board has lost sight of the main control board , but its been my experience that this maybe able to be reset and it may never come back or it will not reset and the control board will need replaced (50/50)
cycling power may reset this
Jan 30, 2016 • Dryers
My kenmore stove is showing f11 after i did a cleaning cycle and i can not unlock the stove top but the door to the oven unlocked. after unplugging it now shows the clock needing to be set and the pf on it...
F11= problem communicating with display
Suggest you unplug unit, peel off front of display and clean this and contacts thoroughly.
Replace - all should be good.
2helpful
What does the f11 code on a kenmore elite he3 washer mean
A bad CCU (main control circuit board) will cause this F11 problem 90% of the time
1helpful
2answers
F11 CODE FLASHES DURING THE SPIN CYCLE
this is a central command error and its something to do with either motor or control
module
1helpful
F11 flashing kenmore he washer
The F11 error code indicates a serial communication failure. This happens when the 2 main control boards are unable to communicate with each other. This is either caused by a loose wiring harness connection or one of the control boards is defective. Good luck and please rate FixYa!
Kenmore Elite HE 5t
Hello
Please see this weblink here for a ton of info on your problem.
F11 = Serial Communication Error. Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Do this = Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
Check the Drive system for any worn or failed components.
Please rate this post, if you are happy with my response. Respond back to this post if you need more help!
Top Adaptec Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Adaptec Computer and Internet Expert? Answer questions, earn points and help others
