While oven set at 350 degrees noticed small amt of black smoke emitting through oven vent, opened the oven and interior was hot, no flames and then noticed display was now blinking F7 and beeping. Tried to clear but this didn't allow me to reset or eliminate F7 beep. Had to turn off breaker to get this to stop.
What's wrong and how do I fix this?
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
