Spirit Fitness Z500 Treadmill Logo
Posted on Mar 30, 2009
L5 code appears after it stops on the Z500 Treadmill
Z500 Spirit treadmill shows a L5 code after it stops. The treadmill appears to start OK, but then stops after starting on the slower speed. What does L5 mean? Maintenance guys from the place we bought it wants to charge at least $80 labor. Can this charge be avoided?
Anonymous
Level 1:
New Friend:
  • Contributor 33 Answers
  • Posted on Oct 01, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
33
Questions
0
Helped
36374
Points
51
LS mean low speed error, Please check the sensor wire( if moor move). if not move please check control board.
  • 1 more comment
  • Anonymous Jun 23, 2010
    hi, LS means low speed Err , Please replace sensor if motor move few min or replace the control board
    sada
  • Anonymous Aug 18, 2010
    please replace the speed sensor
  • Paul
    Paul Sep 21, 2018
    l5 Means that the machine is not getting a signal that there is movement, ie the speed sensor is not picking up correctly. Move the sensor, ie slide it closer to the wheel. This worked for me
5 Related Answers
Anonymous
  • 79 Answers
  • Posted on Feb 09, 2010
SOURCE: How do I download a manual for a Spirit Fitness Z500 Treadmill
http://www.spiritfitness.com/ownersmanuals.asp just keep it in a folder and go!
Anonymous
  • Posted on Jan 18, 2011
SOURCE: new free spirit treadmill - L5 code what does it mean?
Yeah - the sensor is the problem... It is magnetic... You can find it next to the wheel on the belt - It is fairly small.... There is a metal disc in the wheell on the belt that is a magnet.. As it passes by the sensor - the sensor registers the magnet and can simply calculate speed based on the frequency of the passes... Sometimes the sensor slides too far back and ergo can`t register the magnet passing by - Then you get the L5 error...
Follow this link to a picture!
http://www.angelfire.com/nm/nickm/freespiritl5.html
Anonymous
  • 8619 Answers
  • Posted on Jan 05, 2010
SOURCE: Describe your Spirit ® XT275 Folding
Hi
Thanks for using FixYa. Please read this out:
How to Troubleshoot a Treadmill
If still the issue is not resolved then you can contact local repair center.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Misael
  • 19 Answers
  • Posted on May 14, 2010
SOURCE: my freespirit treadmill showsL5 on nthe display then quits
If calibration doesn't work replace controller.
maxtreadmill
John Mazmanian
  • 832 Answers
  • Posted on Feb 28, 2010
SOURCE: Landice L7 gives me a L5 reading on the screen
Your L7 error looks like L5 , but its really LS which mean lost signal. Unplug unit take motor shroud off then plug unit back in wall outlet. When looking in front unit you will see a Motor control board and there are LED lit up one of them should be an amber light this is you speed sensor which is attached to the top of your motor. Manually rotate the fly wheel and see if that light flickers if it does then your speed sensor is working properly if not replace speed sensor. The next thing to look at is the motor brushes to if they are worn unplug unit you should see slitted caps on both side of motor remove them if they are less than 3/8" they need replacing. That for the most parts should take of your problem. Call Landice @ 1800-526-3423 have the serial# handy their on all the components in the unit
My free spirit treadmill start slow picks up speed and then stops. Code reading is L5 soo what is the problem
Hi there!
L5 sometimes may refer to LS(Low Speed). There might be a problem with your motor sensor. It is best to call the place where you purchased this device for possible replacement if a reboot will not suffice.
Z8 is showing L5 cant seam to fix this
Dear Sir:
I will try to help you, please use the steps with patience and carefully: You must need some basics tools; Included Dvom (Digital Voltemeter).
Instructions Things You'll Need for to Reset Code:
  • treadmill (all models applicable)
1.
    • 1
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
    • 2
Press the "ENTER" button three times to access the treadmill's error log.
    • 3
Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
    • 4
To view the treadmill
Machine shuts off when i press incline up. Belt and board look ok
THis sounds like a controller board problem. In many of the treadmills I have seen the same board controls the drive motor and the incline motor. If this product is under warranty have the company covering the warranty check it out. Anytime you buy one of these machines buy the extenced warranty. I was a field service tech for a warranty company. When you call in with a problem make it sound severe.. I have replace almost everything in one except the frame just to make a customer happy. I am not sure of the error message but i seem to remember it being associated with the controller.
Treadmill powers off when pressing Incline Increase "br 1" error
You may have a beltand deck problem. Test by the following procedure:
without the poweron stand on the walking belt, push the belt in the, direction it normally turns. If the belt is very difficult to turn (on most treadmill this means that you have high belt/deck friction I first apply silicone lubricant between the belt & deck to see if that clears up the problem. Most problems originate from the belt and deck 75 to 85% of the time
1helpful
2answers
12helpful
3answers
New free spirit treadmill - L5 code what does it mean?
Describe your Spirit ® XT275 Folding Treadmill Problem - serial number 90488105100032rev-00 I started the treadmill as I normally do by pressing the start button. The belt does not move. I think...
Hi
Thanks
Rylee
No power to the console of my Spirit Z500 but power button lights
Did you insert the safety switch key to activate the console.
Top Spirit Exercise & Fitness Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Spirit Exercise and Fitnes Expert? Answer questions, earn points and help others
