TV GUIDE SYSTEM HAS BEEN WORKING PERFECTLY, UNTIL SET WAS MOVED DOWNSTAIRS TO LOWER FLOOR, AND SET UP THERE... NOW UNABLE TO DOWNLOAD TV GUIDE ON SCREEN SYSTEM,WITH PROGRAMING.....clock is showing correct time...set is on cable antenna..
I think I may have the "answer".
I am in Atlanta and have a
Panasonic DVR that was working fine and sometime during the past month
or so we lost the channel listings. I've tried many resets as well with
negative results.
I called Comcast tonight. The agent helping me
took a long time to research the issue and gave me this answer (which
sounds reasonable). By the way, this is for the Atlanta area and may
not be applicable to other areas of the country.
Due to delays
in the conversion to broadcast digital and the fact that Comcast is
experiencing bandwidth issues, they have digitized the "channel
listing" signal. By mid-June Comcast's signal will be all digital and
you won't be able to watch a TV connected directly to Comcast cable -
regardless of whether it has digital or analog tuner (or both). This is
contrary to what I'd heard before.
After mid-June, you'll either
need to use a cable box OR what she called a "Digital Transmitter
Adapter" (let's call it a DTA). Prior to being converted to "full"
digital, you'll get notification from Comcast. She said I'd be able to
get 2 DTAs at no charge (I currently have one Comcast HD DVR box).
Additional DTAs would be $1.99 a month. DTAs will only provide access
to the "basic" cable channels, but the good news is that the Panasonic
DVR should be able to obtain its channel lineup through this DTA box.
If you have any questions, please feel free to contact me directly at [email protected]
Good Luck!
