I went to: I went to:
http://www.eddiebauer.djgusa.com/usa/eng/Instructions
and found my bassinet 10330 instructions here:
http://www.eddiebauer.djgusa.com/usa/eng/DJGFiles/ProductDocuments/2657_1-12-2007_25435.pdf
Call 18005441108 to have the instructions emailed to you with 5-10 minutes or I have uploaded them to this site and they will be posted within 24hrs. Also if you need replacement parts this number will also assist you with them.
It's very easy...just remove the center phillip screw on each inside brackets. (there are three screws on each end - unscrew the middle one only). The bassinet lifts off and you can remove the bedding. The manual is at http://eddiebauer.djgusa.com/ than go to bassinets.. Greg in Detroit <>
I bought this older eddie bauer bassinet, looks very similar to the newer ones, but has no Eddie Bauer Logo on it. When I got it home I noticed that it had an odor of gasoline(not thinking it would have been stored in a garage) Is there a way to take off the bedding/ruffle/hood to machine wash it?
Also, can you buy a replacement bedding and if so where? thank you.
"I have uploaded them to this site and they will be posted within 24hrs."
Are these instrustions on here on thsi site (posted by Jessica77)? How do I find them.
Went to EB website, instructions not there. called 1800 number, and they are closed. Help finding the instructions on the weekend would be very helpful.
Thanks!
When taking the top cover off to clean it my boyfriend was messing with it you take the top screw off to the musical side then that pops off and you then loosen the screws on either side of the rocking bassinet to pull off the bassinet to take off or wash the cover if u need any other things let me know it took a few times to figure out that you didnt have to undo this from the wood
Very helpful
Very helpful
Have a car seat model 22-864-bal took apart to clean cover cant figure how to put together
I need instructions on to assemble this product:
Eddie Bauer Wood
Bassinet -Light Oak
10330WOW
Sometimes you can go to your web site type in { industrial, put in the name of the product then type in manul } alot of the time you can get a manual for it. I done this when I was looking up a manul for a fax machine.
I was able to download the instructions from eddiebauer.djgusa.com/instructions/
I need assembly instructions.
Same sad story....received as a hand me down and haven't the first clue how to put it all together!
I had the same problem. Someone gave me theirs that they were getting rid of, but it was totally broken down and missing some of the parts. I found the instructions off of a link on this site:http://eddiebauer.djgusa.com/product/det...
and found exactly what I needed (including a number to purchase replacement parts). Fixya.com was very helpful - Thanks!
Need instructions tried the link no luck
we received a used bassinet without instructional manual and do not know if we are missing parts.
We just received the EddieBauer musical rocking basinet as second hand and fully assembled. To get it to our daughters we need to take it apart and put it back together.
ive recieved this bassinet with no manual and im having a hard time putting it together. im epecting in the net 2 weeks and would really like to have it before than
I need instructions on how to put this bassinet together
i need instruction on how to put this bassinet together
We have a second hand bassinet and need help to assemble it.
Need Instructions on how to put together.
doesn't rock. Plays music,any instructions
