If your TCL TV is continuously going into setup mode every time it is turned on, it can be frustrating. Here are a few troubleshooting steps you can try to resolve the issue:
1. Power Cycle: Turn off the TV and unplug it from the power source. Wait for about 1-2 minutes, then plug it back in and turn it on. This simple power cycle can sometimes help reset the TV's settings and resolve minor glitches.
2. Factory Reset: Perform a factory reset on your TCL TV. Keep in mind that this will erase all customized settings and return the TV to its original factory settings. To do this, navigate to the TV's settings menu (if possible) and look for an option to perform a factory reset. Refer to the user manual for specific instructions on how to access the settings menu and perform the reset.
3. Check Remote Control: Ensure that there are no stuck buttons or issues with the remote control. Sometimes, a stuck button can cause the TV to enter setup mode. Remove the batteries from the remote control and try turning on the TV using the buttons on the TV itself. If the issue resolves, you may need to replace or repair the remote control.
4. Software Update: Check if there are any available software updates for your TCL TV. Visit the TCL support website and search for your TV model to see if there are any firmware updates available. Updating the TV's software can help fix bugs and improve overall performance.
5. Contact TCL Support: If none of the above steps resolve the issue, it's recommended to contact TCL customer support for further assistance. They can provide you with specific troubleshooting steps for your TV model or advise on potential hardware issues that may require professional repair.
When contacting customer support, provide them with the model number, a detailed description of the issue, and any troubleshooting steps you have already attempted. This information will help them assist you more effectively.
https://www.youtube.com > watch
PREVIEW
2:47
I show you how to fix a TCL Roku TV (smart TV) where its not connecting to the wifi internet network (No Connection). By the end of this ...
YouTube · WorldofTech · Sept 16, 2020
Missing: 65R625 ‎' Must include: 65R625
Okay Welkins, try to power of the tv and power it on by keep on pressing POWER-BUTTON and MENU-BUTTON at the same time,... and see if the tv start into de menu mode....if it does...just keep on using volume "up and "down" button combined with channel "up" and "down" buttons to select an reach the UNLOCK-MODE...most of the time the MENU button will be the enter button after each sellection....hoping to inform you correctly I remain,Yours Friendly.
I have the 32" TCL and the 645 code also worked with the 722 dish network dvr remote (remote 20.0 IR). For that remote, press and hold tv button until all device buttons light up, enter 645 and press # key.
use your camera on your phone and point the remote at the camera lense, you will probably find the remote is lit up and the remote is the problem, button on the remote is stuck and sending signal to the tv all the time until the batteries go flat. if its not that then the tv main av controller board has a fault. there area on the board for remote signal control.
If you don't have a code you can do these steps to get your universal remote working with pretty much any tv:
1.) Turn your TV on. Then on your remote press the set button, it's the small gray button above the green button that says TV.
2.) Press the TV button. There should be a red light to the right of the SET button. This means that your remote is ready for the TV code.
3.) To find the TV code, press the + or - on your remote. This is located above the orange buttons. Once the volume on your TV goes up or down, stop pressing the + or - button.
4.) Then press the SET button again to set that code for your TV.
If the above steps do not work, keep trying. It will work! ;)
most universal remote would work like this... press butons tv and power on at same time till red light of remote lights still. then press 110. then presto, it works... i hope i help in a way.
