Was doing a recover on my gateway sx2370 pc & had a power outage. now all i get is the msg "windows unable to complete installation. to install windows on this computer restart the installation. windows 7 was preinstalled on this when purchased from fry's. have tried another hard drive with same results.
SOURCE: tried to install a used 20gb working hard drive
Hi I'm Rain.
The problem is that you have to diffrent system models. When Windows is booting up for the first time it loads the neccesary Drivers for the system model. You will have to obtain the Windows disk and do a system repair or a full Clean install .
This will load all the drivers for your system model.
You can try rebooting and hitting F8 to get to advanced settings.in Advanced settings select Last known good configuration.
If this fail . The configuration is wrong and Windows won't boot.
SOURCE: want to comp re format hard drive and then install
well if u have windows 7 disc, then u can use that to boot the computer from the disc n then it will give u option to format the hard drive and install the new os.
u will have to boot the computer from the windows 7 bootable disc.
SOURCE: Gateway OS Restore for Win XP Home fails.
try alternate drivers for the intel chipset install dont load the ones on the cds
SOURCE: Setup was unable to verify drive C:.
hi ;
this sems to be a memory problem;
in bios , try to decrease the memory for your card to resrve a memory space for the installation program,
if this does not work , it might be your VGA card.
Drivers for Gateway products may be found on the Gateway Product Support. Search for the product and download the drivers.
Alternatively, the factory installed drivers and applications can be re-installed by using Gateway eRecovery by following these steps:
Note: For older Gateway products, the Gateway eRecovery Management program may not be available.
If you do not have a set of Acer Recovery Media, they may be purchased from our Acer Recovery Media Order Form.
