HELP!!! My Samsung YP-T9j won't turn off and is stuck with a screen that reads Automatic Test F/W v1.67. I tried to reset multiple times utilizing the Menu/Rec buttons....it acts like it is trying to reboot but then ends up back on the same screen. I let the battery uncharge completely then charged it completely. I was able to look through the menus but it still would not power off and went back to the Automatic Test screen again...help
Menu and A/B(rec) together turned off the bluetooth. thanks.
Hold Menu and A/B to turn it off.
In my case, firmware upgrade didn't help.
Have you tried connecting it to your computer and attempting a Firmware re-load? There should have been a disc supplied which holds the software that operates your player. Firmware crashes are quite common on various machines, ans a re-load often sorts it. How old is the player? Worth checking the manufacturer's website to see if they've updated the Firmware.
my mp3 said bluetooth mode and it wont play my song
i turn off my mp3 but it would turn on back again by itself
my mp3 player froze while adding music to it and it says connected on the screen and charging it wont shut off
yes , i have ecxactly the the same problem i cant turn it off, :(
wont shut off
HELP!!! My Samsung YP-T9j is stuck with a screen that reads Bluetooth Mode F/W v1.24. I tried to reset multiple times utilizing the Menu/Rec buttons....it acts like it is trying to reboot but then ends up back on the same screen. I let the battery uncharge completely then charged it completely. and when i tried again it still went bac to the screen that said bluetooth mode. ive tried everything and nuttin works. please help me. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
My Samsung is stuck in the transferring files mode after trying to download some songs from my computer. It is advising me not to disconnect, but it won't do anything else. I disconnected after an hour and tried rebooting, but nothing. I can't even get it to turn off.
tengo el mismo problema y no se como repararlo alguien sabe?? me aparece automatic test mi correo [email protected]
same as this guy
Tried the rec a/b button and menu button and then downloaded the things but it still ownt work
I have the same problem with my Samsung YP-S3
