HP PSC 1410 All-In-One InkJet Printer Logo
Posted on Jun 05, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't scan with Canon MF printer with New 64 bit laptop
I bought a new HP 64 bit laptop. I have the Canon MF5750 printer. I called Canon and they helped me download the driver so I can print. They said they haven't created a driver to allow the printer to scan. I used to use the Canon toolbox to scan and I had to select save to make it scan but it worked. Any suggestions would be great. Any free websites that use your present scanner with their software would be great. I really need to scan for work but I like my present printer.
  • 2 more comments
  • Anonymous Apr 29, 2009
    I have win xp SP2, but it won't allow me to scan although I used to be able to. No clue whatsoever, it always prompts:"cannot open the scanner" and used by other process, etc
  • rocouto Apr 30, 2009
    My HP PCS 1410 not imprime. because?
  • Anonymous May 20, 2009
    Same thing - using the Canon MF5750 on a 64-bit machine - scanner drivers not working
  • Brett Duxbury
    Brett Duxbury Jun 05, 2017
    is this a windows 10 64 bit operating system ?
    Did you download MF5730_5750_MFDrivers_W64_us_EN.exe
    fromhttps://www.usa.canon.com/internet/porta...
Jay Plesset
Level 3:
  • HP Master 2,942 Answers
  • Posted on Jun 05, 2017
Jay Plesset
HP Master
Level 3:
Answers
2942
Questions
Helped
667726
Points
9879
You might try "viewscan". there is a free trial, but the software is not free if you want to use it for long.
https://www.hamrick.com/vuescan/supported-scanners.html
5 Related Answers
Anonymous
  • 57 Answers
  • Posted on Jan 10, 2008
SOURCE: Scanner not working
I understand that you are unable to scan after upgrading the compuer from ME to XP.
Please follow the below given instructions to resolve the issue.
Check for the communication between the computer and the printer as scanning needs bidirectional communication unlike printing.
To isolate the issue I suggest you to try scanning from the Windows Image acquisition(WIA) wizard on the computer.
Follow the below steps to Scan using WIA
1.Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2.Click Start then Click All Programs then Click Accessories then Click Scanner and Camera Wizard.
3.Follow the Scanner and Camera Wizard instructions to scan images to the computer.
If you are unable to scan using WIA, confirms that the issue is with USB drivers, please follow the below given instructions to refresh USB drivers:
1. Save and close all programs that are currently running.
2. Click Start, select Shut Down, and choose Restart the computer.
3. Press the F8 function key, this will display the Windows Startup menu.
4. Select Safe mode.
5. After Windows loads in Safe mode, right-click the My Computer icon and select Properties.
6. Select the Hardware tab and click the Device Manager button.
7. In the Device Manager Window, double-click the Universal Serial Bus controllers.
8. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
9. Click OK to confirm the removal of the device.
NOTE: Repeat steps 8 and 9 until all the devices under Universal Serial Bus Controller are removed.
The USB port is now uninstalled.
Now, restart the system. The system automatically detects and reinstalls the USB port.
Then try scanning from WIA and if that works try scanning from HP Director.
Please click on Start>>Programs>>HP>>HP Director.
If unable to scan from HP Director, search for the file " hpqscnvw " in C Drive which is the executable file for Scanning.
Double click on My Computer to open it > C Drive > Programs files > HP or Hewlett Packard > Digital Imaging > Bin Folder. Check for the file " hpqscnvw " there.
If found double click on the file to and try scanning. You can also save the short cut of the file to desktop and can use that file for scanning.
Run the scan diagnostic utility to resolve the issue.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=oj-45265-1
ScanDiagnosticUtility_ver_1.5.exe
Just copy and paste the entire link into the Internet browser's address bar and press enter
If you are able to scan from computer, then follow the instructions from the below given article to scan from the printer front panel.
Here is the web document:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00503569&cc=us&lc=en&dlc=en&dlc=en&lang=en
Just copy and paste the entire link into the Internet browser's address bar and press enter.
This should resolve the issue that you are experiencing with.
Regards,
Lawrence
TrytoFix01
  • 91 Answers
  • Posted on Dec 11, 2008
SOURCE: hp photosmart 2710 missing scanner software/driver
When you download the driver don't get just the basic driver this will not allow the buttons on the device to work.  You must download full feature software.  This is usually a very large download and will take some time.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/larry_1fe25e09c54eece2
Anonymous
  • 57 Answers
  • Posted on Dec 29, 2008
SOURCE: hp laserjet 1000 series no driver update for vista 64-bit
Go here and try this Driver it should clear you right up if not comment back here and i'll get you some more info as I find it :) http://www.opendrivers.com/driver/241620/hp-universal-print-driver-pcl5-4.1-windows-xp-x64-2003-x64-vista-x64-free-download.html
Quickfx PC Repair
  • 846 Answers
  • Posted on Feb 12, 2009
SOURCE: Driver for hp 1001 and LBP 3000 canon
Here are the links to the driver download pages
HP Printer- CLICK HERE
Cannon- CLICK HERE
Hope this is what you needed.Thank you for stopping by Fixya! Feel free to leave a Fixya rating if this helped.
Anonymous
  • Posted on Jul 13, 2009
SOURCE: 64 bit laptop not compatible with ImageClass MF 5750 to scan
I have Windows Vista Home Basic. I anm using 5750 scanner after downloading the following software MF5700_PrtDriverV300_Win_EN.exe &MF5700_PrtDriverV300_Win_EN from the Canon site. I am not an expert in knowing what are all these. But it just worked after downloading them and running.
How can I get my Canon MF 5750 downloaded to my new computer with Windows 7?
Click here Click on above link select os and download driver and install. Let me know if you need further assistance. Thanks for using FixYa.
I need a 64 bit driver to make my Canon 5700 Image printer compatible with my new computer. I understand that I must get a disk to do this. Is this true? How do I get the disk. [email protected]
It looks like you might be able to download this directly from Canon's Support website.  Here's the link directly the download section for this Printer.
http://goo.gl/WcTBN
Just pull down where it says "Select OS" and pick your 64 Bit Operating system from the list.  If there is a 64 bit driver available, it will be displayed (just to try it, I choose 64-Bit XP and it showed me a driver for that).
Toolbox 4.9 cannot find scanner and wont scan. is canon toolbox 4.9 32 or 64 bit.
depends on your operatings system. xp is 32 bit,both windows 7 ad vista can be both,theres an easy way to check,go to start>Control Panel>System and Security>System information. that will tell you what it is
2helpful
3answers
I have hpm1005-mfp printer and want to install the same in my laptop having windows -7-64 bit OS.I have downloaded the same from hp driver site.Printer is working but i am not able to use scanner in the...
Maybe the software that was installed is not the correct one for the all in one .So check the HP site once again and see if there is a new link to get your software or post a query to them .
24helpful
7answers
How to get Canon MF toolbox to work with Win7 64bit.
I got mine to work. Just set the compatibility mode for the .exe file to Windows XP (Service Pack 2).
2answers
k24674
Grand Canyon Tech
Grand Canyon Tech
