Uploaded firmware upgrade as suggested. Locked out can't run install program. I think the upgrade was wrong I used the program search upgrade. I think it was the wrong revision. Should have been for E3. How do I reinstall the proper firmware? I must need a special program for installing firmware bin file? Garry
SOURCE: upgrade firmware
Step 1. Create a Folder on the Desktop Screen: From a blank spot the Desktop Screen, press and hold the Control key on the keyboard and click the mouse button. Release the Control key, click New Folder, and name it firmware. Step 2. Retrieve Firmware from Website: Click link below and download file to the folder created in step 1. Download DI-604 Firmware here - http://support.dlink.com/products/view.asp?productid=DI%2D604#firm Download Di-614+ Firmware here - http://support.dlink.com/products/view.asp?productid=DI%2D614%2B#firm Step 3. Upgrade the Firmware: A. From the Main Desktop Screen, launch Internet Explorer or Netscape. B. Type 192.168.0.1 in the Address bar and click Go. C. For the User ID, type admin and click OK. D. Click Tools on the top and then click Firmware on the left side. E. Click Browse>Desktop>firmware, double click di6xx_firmware_203.bin and click Apply. Wait for approx. 15 seconds or until the M2 light stops flashing on the DI-6xx unit then click Continue. F. This takes you back to the Tools page. Check the Current Firmware Version on the Tools page to confirm that the firmware loaded successfully.
Step 1. Create a Folder on the Desktop Screen: From a blank spot the Desktop Screen, press and hold the Control key on the keyboard and click the mouse button. Release the Control key, click New Folder, and name it firmware. Step 2. Retrieve Firmware from Website: Click link below and download file to the folder created in step 1. Download DI-604 Firmware here - http://support.dlink.com/products/view.a... Download Di-614+ Firmware here - http://support.dlink.com/products/view.a... Step 3. Upgrade the Firmware: A. From the Main Desktop Screen, launch Internet Explorer or Netscape. B. Type 192.168.0.1 in the Address bar and click Go. C. For the User ID, type admin and click OK. D. Click Tools on the top and then click Firmware on the left side. E. Click Browse>Desktop>firmware, double click di6xx_firmware_203.bin and click Apply. Wait for approx. 15 seconds or until the M2 light stops flashing on the DI-6xx unit then click Continue. F. This takes you back to the Tools page. Check the Current Firmware Version on the Tools page to confirm that the firmware loaded successfully.
SOURCE: All I did was reset my Router Now it says i'm coneccted but nothing.
You need to access the router setup page:
To access the configuration utility, open a web-browser such as Internet Explorer
and enter the IP address of the router (192.168.1.1).
Type “admin” for the User Name and “admin” in the Password field.
To access the FIRMWARE UPDATE setting window, click on the Firmware Update button under the MAINTENANCE tab.
FIRMWARE UPDATE
To update firmware, click on the Browse… button to
search for the file and then click on the Update
Firmware button to begin copying the file. The Router
will load the file and restart automatically.
SOURCE: D-link DI-524 firmware problem
Sorry - I've been out of town. A few things. Just in case you upgraded the firmware through a wireless connection you should never do this. Let me know what operating system you're using just so I know. Before you actually reset the router to factory defaults, if you haven't done it already, I want you to go to a command prompt. In XP start>run>type "cmd" without the quotes and then click on ok. In Vista click on start to open your search box and type "cmd" When you click ok it may ask for your permission so just tell it to go ahead. At the prompt type ipconfig and let me know the sets of numbers that come up. Read through this and please answer all the questions when replying. Thanks.
Jeff
P.S. - Also if you want, if you don't have it fixed yet, send me a email at [email protected] I might have a quicker way to fix this than sending comments back and forth all day and night.
SOURCE: Will not upgrade to latest firmware
The newest firmware version is actually v 2.01.
The file should be called DI634M_firmware_201.bin and is engineered for North American products only. Does that apply to you?
You can get the file here.
Important! - Make sure that you use only hard-wired network connections for upgrading. Do NOT upgrade firmware on any router over a wireless connection. This might result in a device failure.
Here is also a page with detailed instructions.
If you have any more questions or this doesn't work for you, just come back here and leave a comment - I'm happy to help.
Find a solution that solve my problem : go to US sony website and download the firmware 1.062 released on 7/12/2011. If you're in Europe you have to rename the zip file like this : A64U_1062.zip renamed to A64E_1062.zip
Then upload it to ES Utility and do the update. After half an hour, shut down your receveir (even if blinking) and restart.
Result, no more message error and everything work fine now! Firmware installed : 1.066 (!)
i think the firmware 1.065 released by sony in november was totally corrupted...
Hope that help someone ++
For North America users only
For users outside Americas - World wide Version
For users in Russia only
1.84 MB
Note: Do not upgrade the firmware using a
wireless connection. Please perform firmware upgrade with "wired" or
Ethernet connection only.
