After a powerfailure, my Krups coffeemaker has a flashing display of 8888. I can set the alarm time (I think) after much trial and error, but I can't set the current time. If I had the manual, I might be able to solve this myself?
Programming Your Coffee Machine
• Plug in your appliance: the display will light up briefly in blue, blink "8888" and then remain
fixed.
• Press the O/I button if you wish to make coffee without using the programmable mode.
• The display will light up in blue and alternately show "ON" and the current time.
• Press the O/I button to shut off the coffee machine. The display will no longer be lit.
Setting and Adjusting the Clock
• The machine must be "off".
• Press and hold the prog button (o) for 3 seconds: the hours will blink "88 _ _".
• Adjust the hours in steps by pressing the h/min button (n).
• Press the prog button : the minutes will blink" XX 88".
• Adjust the minutes in steps by pressing the h/min button.
• Confirm the setting by pressing the prog button.
Setting Auto On
This programs the coffee machine to start automatically at the set time each day.
• Press the prog button (o) briefly : the display will blink "prog" for about 1 second, followed
by "8888".
• Press the prog button briefly: the hours will blink "88 _ _".
• Press the prog button briefly: the minutes will blink "XX 88".
• Adjust the minutes in steps by pressing the h/min button .
• Confirm the setting by pressing the prog button briefly:
• The display (q) will show the time and a " ".
• Press the h/min button to cancel the programming.
Click the link below for the maunal:
http://www.krupsusa.com/NR/rdonlyres/A50B1840-2CD9-44C1-87E8-260B92D96D3A/7244/FME124_FMF345_usa.pdf
Hope this helps!
zeppelinx12
