Sony DVP-NS305 DVD Player Logo
Posted on Aug 28, 2007
My DVP-NS305 DVD Player shows as locked, i cannot eject the current dvd, it will play but will not eject. i have tried to hold down the eject and stop buttons together as in similar advise given on other sony models but this does not seem to release it. i'd appreciate your help. cheers jim
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 24, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1602
Points
T-lock means it wants you to take it in, pay gobs of $$$$$$ to fix whats not broken, i popped the top, pushed tray out and use it that way, you gonna pay $150 just for them to do that when u paid $29 for a machine worth not even $1, sony is junk, is has and always will be.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 04, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1477
Points
Your system is in child lock mode. I had this exact problem this week. You need to put the system into standby mode and then press return, then enter then on/off and it will be unlocked.
A
Anonymous
My SONY DVD player/recorder suddenly got LOCKED and I couldn't open the tray.
Put the DVD player in standby and keep the STOP button pressed until tyhe tray is unlocked.
37helpful
5answers
4helpful
Tray locked on sony dvp-ns77h dvd player
If the Sony DVP-NS77H DVD player displays "TRAY LOCKED" and you can't eject a disc or open the tray, try the following - First turn the unit off. Then, while holding down the eject, play and stop buttons simultaneously (on the front of the DVD player), turn the unit on with the '/O button (also on the front of the player). This released the locked tray for me.
1helpful
When truning on my dvp-ns305 the red light becomes green for just a few seconds. The display begins to show "welcome" but stops before it is finished.
when truning on my dvp-ns305 the red light becomes green for just a few seconds. The display begins to show "wel" but stops before it is finished.
I have a sony dvd player model dvp-ns305 i live in rhodes greece family send me films on formatted discs but my player says can not play this disc? can you give me advice or solution
If it plays other bought discs, then maybe your DVD player has been configured not to play pirated discs or the films weren't copied well.
My DVP-NS305 was playing all DVD's (multi-region) in colour but now only shows them in B&W. How do I change it back?
you can change colour setting in dvd setup to auto.after that colour come.when change setting power off dvd play then i will work fine.
My sony dvp-ns305 Dvd player will only play in Black and white.
first try to check the setting if its in ntsc or pal same with your television
1helpful
Sony dvd/video combo dvd stuck inside
will it play the disc? try giving the door a little help when ejecting sounds like a slipping drive belt.farr64
3answers
Is it multi region already?
not u would have to set the code to 0 all sum do sum dont usally need a unversal region free player out of box to do it
Player won't play any disks only says CANNOT LOAD DISK
change the way you connect the dvd player to your tv
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
