I need some help! I am installing a rearview LCD monitor mirror in my 2005 Honda accord coup. I have completed almost everything but acquiring the power source for the actual mirror. I was able to remove the housing for the dome lights, which Honda nicknamed the "spotlights" and gain access to the power sources. There are two "plugs" that power the lights one is green with four wires, none red and black, and another which is beige that has two wires (one green and one white with a back line on it). I am attempting to tap into one of these power sources. I do not know which one I need to use and which wire corresponds to the red and black wires coming from my 12v mirror. I don't need to worry about the unit receiving continues power, it only powered on when the camera is receiving power, when the car is I reverse. Any help would be greatly appreciated! Thanks
SOURCE: Fog lights are not working.
The lower Fog lights to my 2003 Chrysler Sebring Conv LXi do not work. And I do not have an owners manual to look at what fuse is what in the relay center near the engine. There are bulbs there in tact on the front ground effects. But they do not come on ever.
SOURCE: Fitting a new car stereo to the old wiring
hmm, this is an old post, do u still need help??
If u do lemme know and i'll give u a few tricks u can use.
SOURCE: Honda S2000 engine installed in kit car. How do I wire alternator
Unfortunately the Honda alternator is regulated by the ECU, which allows the ECU to intelligently reduce alternator engine loading to improve fuel consumption. The intelligent system uses an electrical load detector (ELD) located near the battery to control the alternator output voltage. A two wire alternator has an inbuilt regulator that will always generate the required charging voltage. When a battery is fully charged and the electrical loading is low there is no need for generating the charging voltage, in this situation the honda alternator will reduce the output voltage to reduce engine loading, hence improved fuel economy.
SOURCE: Installation of Zero 4 powered side mirrors
sounds like your mirrors that came on the car were heated and the ones you are replacing them with are not thats why the extra wire on yours.
