Casio DB360G-9A 30 Pages Telememo Watch Logo
Posted on Mar 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lost my user guide, cant remember how to adjust analogue time.
How do you adjust analogue time?
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Mar 30, 2009
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1814081
Points
13579
Try this:
http://world.casio.com/wat/download/en/manual/
Rate, please.
I cant set the arm time
[PDF]The Apple Watch User Guide (PDF)
https://manuals.info.apple.com/.../apple_watch_user_guide.pd...
Apple Inc.If you have difficulty seeing the Apple Watch or iPhone screen to set it up, .... Note: If you disable your passcode, you can't use Apple Pay on Apple Watch. ..... Alarm • Timer • Stopwatch • Battery charge • World Clock • Your monogram (displays ...
[PDF]Cal. 7T62 - Seiko
www.seikowatches.com/support/ib/pdf/SEIKO_7T62.pdf
SeikoYou are now the proud owner of a SEIKO Analogue Quartz Watch Cal. .... into consideration the time required to set the ALARM hands and to adjust the .... The single-time alarm cannot be set for a time more than 12 hours ahead of the current ...
How to Set an Alarm on the Apple Watch - YouTube
Dec 26, 2015 • Watches
24helpful
2answers
How to set the time for casio aw-591(4778) details about mode,adjust ,reverse and forward
press and hold adjust button until digits flash (the digit that flashing is changeable by reverse and forward) mode is to choose what you are about to change. if your done with the digital time, press adjust once. for analogue time: press mode button until it reaches the word "H.SET" press and hold the adjust button then the word H.SET replaced by the time that you had been set for the digital time. then you can now use the reverse or forward to set the analogue time. if your done press the adjust button once then the mode button once. i hope i had been helped you.
3helpful
How to change the time display
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all NIKE watch manuals.Rate me, please.
2helpful
Lost instruction to a digital/analogue pod watch
This watch appears to be made by "Suunto" and if you go to their web site, you should be able to find your watch detailed there.
If you then go to "support center", you will see "download center and user guides.
Jan 03, 2010 • Watches
How to adjust analogu time ?
How to adjust analogu time in casio 3768 amw-200
8helpful
2answers
I cant set analogue time on casio hd wrist
Follow this link:
Rate, please.
2helpful
2answers
Have a casio watch with analogue and digital time.  can change analogue time but not digital time
Digital time must be set using pushbuttons on watch case sides. One of them is for MODE, another for SETTINGS.
Mode button usually must be held pushed in for a while to start to work and the digits should start to flash - only then you can start to reset your digital watch using another (settings) button.
Use small steal pin to push these buttons.
If nothing happens, you will have to consult your nearest watch repairer as in this case there is a mechanical or electronical fault.
Rating is very appreciated.
Jan 05, 2009 • Watches
2helpful
3answers
Setting Time
Hold in the adjust button until the seconds start to flash. Then push the mode button until the hour is flashing. When the hour is flashing push the forward button to advance it one hour. After you do this hit the adjust button to exit the set mode.
Mar 09, 2008 • Watches
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
