I have a vintage Stradivaro sewing machine, had it tuned up last year so it's in great shape. Problem: I plug it in and it begins sewing right away. There is no on off switch to control it, further more it only has a knee presser foot. Pressing the foot in has no effect. It just goes! Does anyone know how i can turn it off/on ? Really want to use the machine! Thanks!
SOURCE: The presser foot came off Brothers sewing machine
position the foot under the shaft making sure the horizontal pin on the foot is in line with the horizontal groove on the end of presser foot fitting on the shaft. Lower the pressor foot arm and it should snap right on. If not, press it up manually. the directions should be in your manual. If you don't have your manual, you can get it online at www.brother-usa.com
SOURCE: presser foot lifter is stuck can i fix it
If you can't lift the presser foot up at all undo the presser bar screw on top of the presser bar, if you have a dial turn it to 0, you should now be able to move the lever, if it is still tight put some WD40 on the presser bar and leave it for a couple of hours.
SOURCE: looking for part for brother ls2125i sewing machine
That foot is available here:
Brother LS-2125 Sewing Machine Parts
SOURCE: I bought a vintage Brother select-o-matic and it
You may have the light plug and the motor plug switched in the case
