Its more then 5 years old, is it better to just replace the ice maker unit completely? sometimes it makes ice but just like shaved ice do you think the water supply is blocked
Hi, I have a similar problem on my Samsung fridge. It could be the faulty of the Ice Maker unit, more particularly on the heating element. To be sure the ice maker unit is faulty, I suggest disconnect/remove the ice maker unit and do the continuity test of the heating element to make sure it's 100% faulty before replacing the ice maker unit.
please note some heating elements are replaceable, and some are attached to the ice maker unit that means you need to replace the whole ice maker unit.
Here is some helpful tips for most all Ice Makers=> HERE When it comes to rebuilding Ice Makers it is just sometimes less expensive to completely replace. You can find part number 5303918344 Complete Ice Maker from many different places like here=>5303918344 Ice Maker Assembly Click here for a parts breakdown=> 5303918344 Ice Maker Assembly I will be here should you have any questions, Thanks, Sea Breeze
Ice maker problems are almost always a problem. Sometimes I will locate an issue and fix it and then it will work for a short period and then break again. So, now I just replace the ice maker as a general rule. This is much more likely for success. However, the replacement ice maker is often not an exact match. And again, the this and the that sometimes causes problems. I will never accept a new customer on the grounds that I am going to fix their home ice maker. Make sure the ice machine is getter water like it is supposed to. Check the filter and the tubes. If the problem persists, get a new ice maker. If that ice maker angers you, get some ice cube trays.
Try to remove the ice bucket and replace it. Make sure the ice maker is completely in the "Up" position. Make sure that the water line is not crimped. Remove and replace the filter again. I hope this helps and solves the problem. Please let us know if we helped you and have a great evening.
maybe but check the icemaker to see if the fill switch is working and the timer might be off. In an old unit it is sometimes better to replace it than put a bunch of time and money into it they are not bad priced these days
Is your Ice bin filling up too much? Frigdaire did have problems with there ice makers, and I belive the new ones come with a arm extention. Your one of the lucky one's and your icemaker still makes ice! I dont know how old your unit is but they were replaceing icemakers under a factory warrenty. I could be wrong but I think they were doing it up to a 5 year old unit.
Make and model please to help.
