See this instruction. God bless you
Park the Honda Foreman on flat ground and leave the engine
running for 5 minutes to allow the engine to warm up. Place the oil
drain pan under the crank case drain plug. Turn the engine off.
Remove the drain plug from the under side of the crank case
using the ratchet set. Allow the engine oil to drain into the oil pan.
Replace the plug to the bottom of the crank case and tighten the plug
Sponsored Links
OilandGasIQ.Com/Oil_Videos
Remove the small screw from the side of the crank case using
the Allen wrench. Remove the cap labeled "OIL" from the top of the
crank case. Insert the funnel into the hole where the oil cap was.
Pour Honda 4-stroke engine oil into the funnel until the oil
starts to come out of the hole where the small screw was on the side of
the crank case. Once the oil starts to come out of the hole, stop
pouring and replace the screw. Remove the funnel and replace the oil cap
to the top of the crank case.
Read more: http://www.ehow.com/how_6512146_change-oil-honda-foreman.html#ixzz2ZPlA2Cu0
