I am getting a problem code H4 for sharp copier when i start the machine. what is the problem. is ther any solution for the problem of the said model.
H4 is a fuser temp error code.
Code h4
SOURCE: code H4 comes up when the sharp copier ar-5316 is switched on
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
SOURCE: I have a sharp copier, model AR-285, H4-01
H4 error pertains to lamp errors.
that would either be the copy lamp or the heater lamp.
check both lamps.
with heater lamps,it's usually caused by either a broken heater lamp or a dirty thermostat on the heater roller assembly.
SOURCE: Sharp -COPIERS - AR-5316
If you go to this web page:
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
You should be able to find the driver for that machine.
Hope that helps.
Lbcoaster
I turned the power supply ON & OFF
I have cheked the fuser unit OK !
the problem code H4 is occured when machine is switch ON
